- Thank you received: 22
International Water pump
13 years 5 months ago #39059
by ray
International Water pump was created by ray
Does anybody have a good water pump or a kit for an International BLD269 engine. Failing this, does anyone know of a company in Melbourne that can rebuild my existing pump. It is a straight inlet that points down at an angle not the one that is angled towards the radiator.
13 years 5 months ago #39060
Ray
GuddayM8
the last inter water pump kit we got a cupla years back twaz from
AUTO SPARES GALORE
924 Burwood Hwy
Ferntree Gully Vic
9758 3644
if not try
Auto Surplus
34 Thornton Cres
Mitcham Vic
9873 3566
or
Rare Spares Bayswater
160 Canterbury Road,
Bayswater VIC
9729 0911
Aust Wide
www.rarespares.net.au
jist thort wot about the Christorphans they run with Inter blood
[ch9787]
Replied by Swishy on topic Re: International Water pump
Ray
GuddayM8
AUTO SPARES GALORE
924 Burwood Hwy
Ferntree Gully Vic
9758 3644
if not try
Auto Surplus
34 Thornton Cres
Mitcham Vic
9873 3566
or
Bayswater VIC
9729 0911
Aust Wide
[ch9787]
13 years 5 months ago #39061
Replied by on topic Re: International Water pump
Ray - Let us know how you get on. If no joy, I should be able to get you a NOS pump within a couple of weeks, for around about $100-120.
Cheers - Ron.
Cheers - Ron.
13 years 5 months ago #39062
by ray
Replied by ray on topic Re: International Water pump
G'day Ron, I will most likely take you up on your offer. I will pull the pump off the Straddle Truck probably this weekend and post some pictures to make identifying it easier.. Ray
13 years 5 months ago #39063
by ianoz
Replied by ianoz on topic Re: International Water pump
Hi Ray , Not sure if it is the right one ,On US ebay Item number 400176663334 ,New water pump Suit 41 to 61 mudel BD and BDL motors .$10 us at the moment. Soild seller by the look of him . Has Photos to ID . . Wagga tractors Have some on ebay as well .Search International water pumps . Ian .
13 years 4 months ago #39064
by ray
13 years 4 months ago - 13 years 4 months ago #39065
Ray - Thanks for that. We're cooking with gas here .. I have the right new pump for you ..
What you need to do, is remove the pulley (carefully), and send me the old housing for the core. I have a small amount of work to do on this new pump .. the shaft and impeller needs to be pressed in a little further, for correct impeller clearance .. and I'll manufacture a couple of new gaskets for you, as I wouldn't trust the original new gaskets that came with the pump, they look a little weathered.
There's a slight design difference in the castings .. this is an aftermarket pump, and it has a slotted hole for one of the retaining bolts. Shouldn't create any problems, in fact, it may make installation a little easier.
I'll send you a PM as regards payment .. and I'll need your delivery address.
Cheers - Ron.
Cheers - Ron.
