- Thank you received: 2
IH 392 V8 - 5 speed main plus 3 speed joey
10 years 8 months ago #125039
by Bugly
IH 392 V8 - 5 speed main plus 3 speed joey was created by Bugly
Can anybody remember the full sequence to use all 15 gears in the 392 V8 Internationals with the five speed box and the three speed joey? I remember that down low it was all round the place, and 14 and 15 were fifth medium then fifth high. 12 may have been fifth low and 13 may have been fourth high.
10 years 8 months ago #125040
by BRS FH66
Replied by BRS FH66 on topic Re: IH 392 V8 - 5 speed main plus 3 speed joey
Is this the V8 Cummins powered ACCO Inter you are talking about?
10 years 8 months ago #125041
by Bugly
I had a stooge around and came across this old post ... interesting!! www.hcvc.com.au/forum/YaBB.pl?num=1247906790
Replied by Bugly on topic Re: IH 392 V8 - 5 speed main plus 3 speed joey
Nope - this be the petrol-hungry International engine fitted to early Inters and ACCOs. Probably also fitted to butterboxes and long-bonnets.Is this the V8 Cummins powered ACCO Inter you are talking about?
10 years 8 months ago #125042
by oldfulla
Replied by oldfulla on topic Re: IH 392 V8 - 5 speed main plus 3 speed joey
Bugly
Many will argue that it wasnt possible to get 15 progressive changes out of those 5x3 combos. But it was - although a couple wernt worth the effort - so 13 was easier and probably the best.
Most drovers only used 10 - just spliting each one in order - using the D to OD in the joey box. And some didnt ever work out what the 2nd stick was even for!!!
Anyway - here is the full 15:
1st UD = 1
2nd UD = 2
1st D = 3
1st OD = 4
3rd UD = 5
2nd D = 6
2nd OD = 7
4th UD = 8
3rd D = 9
5th UD = 10
3rd OD = 11
4th D = 12
4th OD = 13
5th D = 14
5th OD = 15
Shifts 5 & 8 didnt do much. And 3rd D to 5th UD was messy but filled the big gap that there was between 3nd & 4th in the main box.
Oldfulla
1st UD = 1
2nd UD = 2
1st D = 3
1st OD = 4
3rd UD = 5
2nd D = 6
2nd OD = 7
4th UD = 8
3rd D = 9
5th UD = 10
3rd OD = 11
4th D = 12
4th OD = 13
5th D = 14
5th OD = 15
Oldfulla
10 years 8 months ago #125043
by Bugly
Hey thanks Oldfulla!! [smiley=thumbsup.gif] [smiley=thumbsup.gif]
I've just been sitting in front of the computer screen with two imaginery sticks, and going through the motions! Yep, that's it alright. And you are correct, all 15 were there able to be used.
The truck I drove in 1982/83 was a Pioneer agitator truck (truck number 002) on the Curragh minesite construction out of Blackwater in Queensland. The guy who drove it before me explained that you used 5 gears in underdrive to go out on site with a load (took a long time to get there though), 5 gears in direct to come back to the batch plant, and 5 gears in overdrive when the truck went into Blackwater for repairs.
10 years 8 months ago #125044
by oldfulla
Bugley
If you drove an ACCO A Series (first tilt cab) - they had a bloody terrible joey box stick set up - p$%k in a shirt sleeve stuff.
The older short and long door C models were pretty good - sticks fairly close together, easy to reach, and pretty short posative shift arrangment. Except for the 1900 series (V185 Cummins) which had the Joey lever fitted between the drivers seat and the door. Where the hand brake usually was. The sow 'run down' with the cummins slowed changes down a bit too.
The old C Series with a Perkins was a pretty good combo. the A Series 6 cly Neuess was a bit slow to respond too - making it harder to get all 15 shifts.
Your instructer fits one of the types I mentioned!! Having said that - going 1st to 5th in Under Drive actually gave a fairly progressive set of ratios - but didnt let you cover much ground.
Oldfulla
Oldfulla
10 years 8 months ago #125045
by Bugly
Yep, and yep. It was an A-series ('1910A' if I remember right) and it was definitely a challenge to make the compound changes, with the right arm through the steering wheel and all that!! The truck ended up breaking down that often Pioneer got pi$$ed off and lifted the bowl. The truck ended up in Gladstone as a water cart I think.Bugley
10 years 8 months ago #125046
by mikeg
Replied by mikeg on topic Re: IH 392 V8 - 5 speed main plus 3 speed joey
10 years 8 months ago #125047
by oldfulla
Mikeg
But i bet you never found a hill that stopped her!! Either going forward or backwards.
Oldfulla
Oldfulla
10 years 8 months ago #125048
by mikeg
Your right there Oldfulla, I don't remember a hill that could stop her. Even with much less HP than the other trucks in the yard, all Loadstars with 345s or 392s, I could go where they just couldn't get to. It was much better off the bitumen than the Loadstars especially backing down on very steep sites when they would often rear up and sit on their drawbars. As a result I used to get pissed off no end as I was usually given the difficult steep sites.
Even though the Loadstars were faster and would sometimes round me up I was always ahead at the end of the week when it came time to pay the fuel bill.
Time to create page: 0.576 seconds
