Ford mechanical Brakes. Advice needed.
10 years 2 months ago #163624 by kw573
Hi all,
I am an occasional poster here and often read the posts, I learn a lot.
Anyway, I am trying to nail down the model of a Ford truck diff/housing/axle assembly from the late 1930's that had mechanical brakes, to use in a project.
I have found that many have an opinion, but when pressed, no-one I've spoken to can really help me.
Did Ford have a truck diff housing, split type with a splined pinion shaft, that used mechanical brakes, that is, the brakes were activated by a pull rod. Not hydraulic.
Any hard knowledge would be greatly appreciated. Or better still, an actual axle assembly that is available.
Thanks.
Have a nice day.
Sam.
WW2 Jeep (Daily Driver)
Diamond T 969 (Under restoration)
Kenworth 573 (Yard truck)
WW2 Water trailer
WW2 Blitz 3 ton GS dog trailer
10 years 2 months ago #163672 by grandad
10 years 2 months ago #163673 by grandad
10 years 2 months ago #163674 by grandad
10 years 2 months ago #163675 by grandad
Hi Sam, here's a couple of pics of the rear axle of a 1931 Ford AA truck here on the Isle of Wight, you can see the two pull rods for the foot and hand brakes. The diagram is I think for a later model, the actuators are behind the axle worked by a single pull rod.
Hope this helps
10 years 2 months ago #163683 by scratcha
the bedford trucks have a similar setup but use a rod to mechanically operate the rear shoes via the wheel cylinders. plenty of these about im told.
1418 Benz now really impressing the bride :-)
10 years 2 months ago #163710 by kw573
Thanks Grandad,
I'm looking for something to use on a Bren Gun Carrier. The original rear axles are very hard and expensive to get. They used a Ford split diff, splined pinion shaft and mechanical brakes with an actuating lever at the bottom and adjuster at the top of the backing plate. The brake drums are also unique and have three distinctive cooling ribs around the outside of them.
Anyone know of one? Or any ideas what I could use?
Thanks,
Sam.
WW2 Water trailer
10 years 2 months ago #163731 by grash
Kw573,
The Bren, being English is similar to the Fordson 7v or ET6. But There are some differences .I don,t know much about Bren Guns but have some spare Fordson parts that might be useful. Send me a pm with phone no. Or see me at Yarra Glen.
Graham .
The following user(s) said Thank You: kw573
10 years 2 months ago #163737 by kw573
Hi Graham,
I'm in Queensland.
The 7v and ET6 are things I have no idea about. What are they?
They sound like tractors?!?
Sam.
WW2 Water trailer
10 years 2 months ago - 10 years 2 months ago #163738 by kw573
O.K., I'll bite.
How do I send a PM? I can't see an icon anywhere.
Maybe I'm just having a 'boy look'. He! He! :whistle:
Sam.
WW2 Water trailer
Last edit: 10 years 2 months ago by kw573. Reason: grammar
Time to create page: 0.295 seconds
