- Thank you received: 4714
Ploughing question for cockies
3 years 11 months ago #209179
Replied by Mrsmackpaul on topic Ploughing question for cockies
Lang you will be ploughing pretty good in few passes
Message me if you need help, I'm not a expert and never ploughed in matches as I only use disc ploughs as moulghboard ploughs aren't suited to Australian soils
Thats another topic though
Only to happy to help if I can
Once you the grain from the chaff so to speak of advice it isnt very hard
Open a paddock correctly
Tractor should pretty steer itself
Maintain a proper speed at all times for a level job
Close paddock correctly
Set the plough correctly before you start
If you gotta fight it you need to adjust the plough
If your running out of power adjust the tractor
If it rides rough adjust the tractor
If it pulls you into ploughed lamd lengthen the top link
If it pulls you to unploughed land shorten the top link
3 years 11 months ago #209181
Replied by Lang on topic Ploughing question for cockies
Great info. Looks a lot harder than learning to fly a plane! But then again you can teach a monkey to fly but not very well. I think we might be seeing a monkey on the tractor seat.
3 years 11 months ago #209182
Set tool post height correctly for proper weight transfer
Sway chains are only used to control the plough when its out of ground and should be fairly loose
I'll thinl of more thongs if you go down this path
3 years 11 months ago #209197
Replied by asw120 on topic Ploughing question for cockies
I have one of those drag grate things down the back here you can have if you want it. It's 5, or 6' square. I'm in Ipswich.
See if I can get a picture after work tomorrow.
3 years 11 months ago #209199
Replied by hayseed on topic Ploughing question for cockies
Lang, here's how to Not Do it.....LOL
www.facebook.com/redneckswithpaychecksof...jc5NTkyNTM4OTc5MTgz/
3 years 11 months ago #209202
Don't see the old FIAT going that good.
3 years 11 months ago #209218
Replied by cobbadog on topic Ploughing question for cockies
Speedy on the fast tractor had a mouldboard plough and is the plough you dont want to use as they leave winrows all the way along.
3 years 11 months ago - 3 years 11 months ago #209224
Replied by PDU on topic Ploughing question for cockies
What the hell is a winrow? Obviously not a win in any row? :whistle: Or it could be, in the right row . . . not to be confused with the wrong row, or the left row, or the middle row or even the next row!? Was that the last row or the penultimate row?
Row, row, row your boat, etc, etc :blush:
Last edit: 3 years 11 months ago by PDU.
3 years 11 months ago #209227
by V8Ian
Replied by V8Ian on topic Ploughing question for cockies
The windrow is the highpoint, PDU. If you think about a grader leveling loose earth, the row of soil running off the side of the blade, sitting proud, is the windrow.
Time to create page: 0.509 seconds
