- Thank you received: 1739
Fiat 55L Pilot motor
3 years 7 months ago #214945
Replied by JOHN.K. on topic Fiat 55L Pilot motor
If you dont want to spend a fortune on a maggy,you can just use the points with a battery and coil ignition.Anything like a coil rewind wont leave much change from $500......The ball bearings aint cheap either.
3 years 7 months ago #214952
An Old Guy I know has removed the Pull starter & fitted a V Belt Pulley to the Pilot Motor. He has an Electric Motor rigged up on a lever arrangement to start his Pilot Motor..
A lot of the Blokes in the local Engine club have similar type arrangement only with an old 12 volt starter motor modified with a small V Belt Pulley instead of the Pinion..
Sure beats Cranking them..
Replied by hayseed on topic Fiat 55L Pilot motor
Fiat55L wrote: . The pilot motor is pull start - no starter motor. Good exercise when you are fault finding ignition trouble .
3 years 7 months ago #214955
You can also use a B&S to start these engines..............some also convert them to direct electric start,but you better have good batteries and plenty of ether.
Time to create page: 0.392 seconds
