Rebuild of AT4114
8 years 10 months ago #125763
by Mac 57
Replied by Mac 57 on topic Re: Rebuild of AT4114
AT4114,
Your certainly putting in the work to get her up to scratch. I noticed the drivers door does not have a key lock in it, so if you want to put it in they are not very hard to do. I found another one and copied the passenger door hole and got it working before I painted mine. To paint my doors I set up an old sheet of ply and screwed the hinges to it and it made it easier to paint the doors. Hope this helps. Keep plugging away it will be a looker when it's finished.
Cheers Mac.
Cheers Mac.
8 years 10 months ago - 8 years 10 months ago #125764
by oldgmc
Replied by oldgmc on topic Re: Rebuild of AT4114
AT4114 your panel work is really good are you a panelbeater
Last edit: 8 years 10 months ago by oldgmc.
8 years 10 months ago #125765
by AT4114
Thanks for the top idea Mac57 I shall be copying you when it comes time to paint the doors hi oldgmc I'm a motor trimmer by trade up until now I have always had a panel shop do any work but on this project I thought I would bite the bulit and buy a small mig welder and some very basic panel beating tools and give it a go fingers crossed it will turn out half decent as its not going to be a show pony just a daily driver cheers Bryant
8 years 10 months ago #125766
by boris
Replied by boris on topic Re: Rebuild of AT4114
Bryant, how do you find the stripping discs on the grinder. do they heat the panel steel. I've been spraying etch primer first then bog, bog is porous. keep it up. boris
8 years 10 months ago #125767
by AT4114
Hi Boris the strip discs are fantastic they don't heat the metal so there's no warping and they leve a nice smooth finish and the bonus is they don't clog up like sandpaper one disc has striped 2 doors at $17.00 per disc it not to expensive . I first found out about the discs by watching a few resto jobs by fellow forum member V8 inter nut cheers Bryant
8 years 10 months ago #125768
by overnite
I have a limited number of these discs available for $10 each. 6" or 7 ", same price. 0411-11-1958
Replied by overnite on topic Re: Rebuild of AT4114
8 years 10 months ago #125769
by AT4114
Thanks for the offer overnight I could have saved a lot of $$ if I knew you had them for sale but I've already brought up big at my local hardware store regards bryant
8 years 10 months ago #125770
by AT4114
Another little update the rust repairs are finished to the underside of the drivers door and have been given a skim coat of fiberglass body filler to fill in any small pin holes during the welding process and the glass filler is also non pourous So it's a good base for the body filler I've also welded up the west coast mirror holes on the door and tapped out a few small dents cheers Bryant
http://i.imgur.com/rtp0i0u.jpg?1
http://i.imgur.com/FsUi6rA.jpg?1
http://i.imgur.com/JX6z5va.jpg?1
http://i.imgur.com/xbibS2S.jpg?1
http://i.imgur.com/dZ2JFzX.jpg?1
8 years 9 months ago #125771
by AT4114
Bit of an update I've started working on the cab it should be ready for etch prime and hi build in the next couple of weeks along with the doors then after they are painted I'll fit the cab back on the chassis cheers Bryant
http://i.imgur.com/0H9yEsK.jpg?1
http://i.imgur.com/rPRxCZn.jpg?1
http://i.imgur.com/mRGB61C.jpg?1
http://i.imgur.com/5lfnvQJ.jpg?1
http://i.imgur.com/SsvXrgs.jpg?1
Time to create page: 0.575 seconds
