- Thank you received: 4851
how much to fix a GM 6V53 ??
10 years 4 months ago #129136
Replied by Mrsmackpaul on topic Re: how much to fix a GM 6V53 ??
hardtopman I dont think you need a special tool to set the injectors you can use a vernier or at least I have properly not that most swishy correct way but it works ok seeya
10 years 4 months ago #129137
Replied by bigcam on topic Re: how much to fix a GM 6V53 ??
HTM, fire it up with out the exhaust manifold on you should be able to put your hand near the exhaust ports and see if they are all the same temperature. With the exhaust manifold on just put your hand on it and the same thing, feel if all the ports are getting hot.
Oil drips out of these things everywhere, even if you do spend some money on a rebuild, so that is no indication of condition.
If one of the ports is cold it will more than likely only be an injector.
10 years 4 months ago - 10 years 4 months ago #129138
by Hardtopman
Replied by Hardtopman on topic Re: how much to fix a GM 6V53 ??
No eBay APP ID and/or Cert ID defined in Kunena configurationAll the grit and dirt in the air box, is that normal for a high milage engine in these things.
Where did you get the tool for setting the injectors Bigcam.
Is this what we need??, but do we need to know what injectors are in there
Last edit: 10 years 4 months ago by Hardtopman.
10 years 4 months ago - 10 years 4 months ago #129139
HtM
RE:All the grit and dirt in the air box
rub it Btween u're fingers
me thinks u'll find it no grit but a oil sludge
Screeemerz thrive on stuff like th@
eye'd say give it a valve adjustment , check injectors R shootn, adjust
n then drive it thou U stole it
RE: Size
printed on the button on side of shootn iron
= N80
me thinkx 80 represents 80 poofteenths of a sqirt
Replied by Swishy on topic Re: how much to fix a GM 6V53 ??
HtM
RE: Size
= N80
Last edit: 10 years 4 months ago by Swishy.
10 years 4 months ago #129140
by 700GMRR
Replied by 700GMRR on topic Re: how much to fix a GM 6V53 ??
whoa look at that oil covered pile of cr...
oh that's my truck
sounds like its making a trip to the hardtopman garage, maybe swishys right and I am being too considerate of the neighbours and need to give it a bit more stick
oh that's my truck
10 years 4 months ago #129141
HTM, the port that is oily is probably the one that isn't firing.
The little tool for setting the injectors is specific to the size of the injector as Swishy says, so if you look at the little button on the injector it'll have N45 or N50 or C 50 or something like that.
I got the tool off Macquarrie's but Cutting Edge's would probably have them too.
The motor in my Dodge, which is the one I put a kit in, uses more oil than the one in my Reo, but the one in the Reo gets a bit more work because it gets hooked up to a trailer occasionally. But oil comes out the exhaust in the Dodge, it is just a sign it needs a bit of a flogging with some weight on it.
10 years 4 months ago #129142
by Hardtopman
Is it worth having injector done up or should we just set them up to height spec's.
Have got hold of factory GM 53 series book
10 years 4 months ago #129143
HTM
there B 2 positions of concern
ifn the injector iz stuk closed meanz no fire n heat from th@ cylinder
Ifn te injector iz stuk open Run do not walk Run coz the injector iz squirtn full time n over revin the motor un controlled by the govonor
only way is to cut off air to the beast
cut n off fuel can work but also the screemer haz ways n means to then go live on the oil in sump
10 years 4 months ago #129144
by Hardtopman
Had another look see at the red Dodge, yes it is not running on front left cylinder. Much colder on this exhaust port. We pulled the rocker covers, the injector is going up and down and the valves have clearance when on base circle
Cracked both supply and return injector lines and had fuel flow no problems.
We have taken injectors from the white truck and are going to fit these into the red truck, as the white truck ran fine just hard to start and loved oil.
these are C50 and we have got hold of a 1.460" injector tool.
10 years 4 months ago - 10 years 4 months ago #129145
by Hardtopman
With the rocker covers off its very clean in the top of the engine which supports the story the heads were done up on it.
And the little injector tool we got hold of
Any tricks to setting up the rack on it when we replace the injectors
We will have the rubber mat ready handy for the intake if things run away on us
Time to create page: 0.540 seconds
