- Thank you received: 2
1948 Fordson E83W pickup
Still trying to think of a way to slip over there, pick it up and bring it back without Mrs Bugly noticing me missing for six days!! :Hey Bugly me thinks you should buy the matching truck and have a his and hers pair blue& pink LOL
I took the muffler and front pipe off ... hmmm - does it look repairable?? Methinks not!!
Beautiful!! The rim is as clean as a whistle, and the red paint showing can be easily wiped off. The reverse side looks great ... back to the original steel. The centre bit, where the tyre fits, has cleaned everything back to the original factory paint. Being under the tyre/tube, this bit hadn't rusted like the rest. I'll stick the rim back in the tank for now, but next week the rims will be blasted with my little gerni, so they will be really clean.
So ... does the molasses treatment work? You betcha it does! As it has taken the rust away and exposed the steel underneath, when it is gernied off next week it will have to have a rust neutraliser or a prime coat fairly quick smart, to stop the rims from re-rusting.
The first rim I pulled from the tank was the one I had a look at last week ...
... and gave it a blast with the Gerni. I made sure that it got a good blast in the rivetted join between the inner and outer portions. Comparing this rim to the one I took out and hosed off last week, it definitely required the second week, as the molasses took all of the remaining paint off.
Next stage is priming and painting. As the rims are now back to fresh unprotected steel, they start developing a surface rust pretty quickly. I gave them a spray treatment with POR-15 'Metal Ready', to protect them, but I'm not sure that that was any better than 'Rainex' or any other phosphoric acid rust-converter preparation.
Now the molasses tank is empty, I could load it up with mudguard, inner wing panels, headlight buckets and a few brackets and things. Next weekend I'll flip the guards over to treat the part that's presently sticking out of the brew.
Yep, I'm very happy Bryant!! [smiley=thumbsup.gif] I hadn't tried this treatment before, so was crossing fingers that it would work. It has turned out better than I had even hoped it would!!WOW Bugly I'm impressed thoes rims look new what a fantastic process well done
cheers Bryant
cheers Bryant
Ahhh...
Another convert to the 'Molasses army'
Honestly Fellas... Try the molasses method if you never have before & prepare to be amazed
Billy
Playing around at Dodge City
Dodge AT4-760&&FB Holden Ute
It's probably been stated before but what is the molasses water ratio please?
Billy
1:10 (1 molasses, 10 water)
ASW.
