K123 Info Required!
10 years 6 months ago #161511
by Gaz92
K123 Info Required! was created by Gaz92
Have purchased two K123's to make one good one I hope! Someone out there might give me some info on chassis numbers, (401603 and 401562)
401562 is the one I want to fix and will fit the BC 400 out of 603, but both engines need fixing.
On another topic, I posted a question on RT12515's is also listed below :
Another question for all you Roadranger experts out there, I'm now going to use a RT12515, one problem, the 12515 I'm going to use has a oil pump on the underside PTO opening, just where I want to put my PTO hydraulic pump, can this oil pump be moved to the side PTO opening, any info would be greatly appreciated!
10 years 6 months ago #161512
Replied by bigcam on topic Re: K123 Info Required!
The oil pump was just to run oil through an oil cooler.
If you aren't going to use it to pull a road train, just pull it off and throw it over your shoulder, it only needs the oil cooler for doing real heavy work. The early 12 series didn't have them.
10 years 6 months ago #161513
by andy950
Replied by andy950 on topic Re: K123 Info Required!
75 models or there about, mine's 401744 and its june 75
10 years 6 months ago #161514
by werkhorse
Replied by werkhorse on topic Re: K123 Info Required!
Sorry Gaz .... Somehow I missed this
401562 K123CR is the middle one of 3 built for the Electricity Commission NSW. 290 Cummins HT750DRD auto SQHD on 38,000lbs Hendrickson.
401603 ... K125CR ...335 Cummins RT9513 SSHD on TBB for J Frazer and Allen
No dates on either but mid to late 75 would be real close
10 years 6 months ago #161515
by Gaz92
Replied by Gaz92 on topic Re: K123 Info Required!
Surprising how much these chassis numbers have changed : 401562, Still has Formula 290, 915 Roadranger and SSHD on Hendrickson.
401603, Big Cam 350, 12515 Roadranger and also SSHD on Hendrickson. Big Cam 350 is about to become BC / NTC400 after rebuild and will be fitted to 401562 and goes back to work again!
10 years 4 months ago #163685
by Gaz92
Would anyone out there have a wiring diagram for my 75 / K123? Would greatly help me with rebuilding, also my rebuild on the Big Cam 400 is progressing, it originally was a BC1 but now will be a BC3 with many mods, should start reassembling shortly when parts arrive!
10 years 4 months ago #163692
by jimbo51
Replied by jimbo51 on topic Re: K123 Info Required!
Check your email Gaz.
10 years 4 months ago #163693
by Gaz92
Thanks a million jimbo! Wiring diagram is just what I wanted, my c/o looks the same as your photo except mine is not eight wheeler, yours is powered by ? I still have to rebuild my RT12515 yet, if I can't find another!
10 years 4 months ago #163705
by jimbo51
Mine's almost original spec, 8V71, RTO910, SQHD's but crow bars have been changed for Foden type rubber block.
10 years 4 months ago #163713
by Gaz92
Jim I have a sad White 9000 rusting away, has a 8V71(Seized). RTO9513, 44Eatons on Hendrickson if you need anything let me know! Thanks again for your help
Time to create page: 0.344 seconds
