- Thank you received: 40
McGrath trailer refurb
6 years 2 weeks ago #192723
by 67mustang
McGrath trailer refurb was created by 67mustang
Hello All
Been a little while but have finally pulled the old trailer and stock crate out from behind the shed on the weekend -
Have taken crate off and put trailer in shed and removed floor, it has vacuum brakes, but i recall on you can swap the S-Cams around and fit Air boosters, any info would be great.
Also any suggestion re timber for the floor, i will oil it once timber is fitted?
It has 8 stud rims so may look at alloys and increasing to 1122 tyres.
The McGrath plaque on the rear has broken but would like to cast one up? any ideas.
Will post a few more photos next week
67mustang
67mustang
6 years 2 weeks ago #192729
Replied by Swishy on topic McGrath trailer refurb
Stang
gudday m8
Yes U can convert to air mechanical
Vacuum mechanical suk the slack adjuster in
air mechanical U need to push the slacky out
swap the left to right cam shafts over
other problem is the vacuum have a very long suction stroke and the slakies R very tall to get the mechanical advantage
U may need to drill new holes to mount the air chamber n push rod down lower (may B 6"-8" (150 - 200mm) from center of camshaft
if U get my drift
gudday m8
if U get my drift
6 years 2 weeks ago #192735
by 67mustang
Replied by 67mustang on topic McGrath trailer refurb
Swishy
yep thought i read something like that on here a long time ago, might put new booster brackets on so the stroke is right, those vacuum ones suck :
67
67
6 years 2 weeks ago #192738
by jeffo
Replied by jeffo on topic McGrath trailer refurb
She must be old ??
I've never seen a strap McGrath trailer, typical of the era was Freighter.
Should be able to find a small foundry that can cast your plate in allubillycan.
6 years 2 weeks ago #192739
by 67mustang
jeffo
think maybe pre 1970 build, looked for a build number near the skid plate but nothing the name plate on there rear is broken and as it has it the number is gone.
Think there was a book on the McGrath trailer but carnt now?
67
67
6 years 2 weeks ago #192744
by jeffo
I'd reckon even before 60's ??
I knew blokes with McGrath semis in early 60's, trailers had those sweet looking pressed channel main beams.
By the early 70's McGrath was offering a "H" section main beam which was lighter than their pressed channel and also cheaper for the customer.
But you could still buy the pressed channel beam version.
Think their UB offering was trying to compete with Haulmark etc who had fabricated "H" section main beams.
6 years 2 weeks ago #192745
by jeffo
6 years 2 weeks ago #192747
by 67mustang
your photo looks around 1966, think my tralier being a strap may be early 1960s as you suggest, will post some photos when i get home
6 years 2 weeks ago #192748
Guess n mid 50'z
6 years 2 weeks ago #192750
Herez our big McGrarth
earn n its keep 24 / 7
with a 20 foot container now @ front gate with a container for sale sign n do n a gr8 job
