- Thank you received: 3051
Bottom Door Hinge
5 years 6 months ago #196471
Bottom Door Hinge was created by cobbadog
Hi Guys,
We have our "Lorry" which is a 1991 FC1491A model Hino with a WO6D 6 cylinder engine. Ha has a beavertail and carries our toys, mostly tractors about to various Rallies and some local show days. Since owning Lorry the bottom door hinge has been, let's say, less than good! There is some wear and tear and as you drive along our lovely roads the doors rattles a lot and now is the time to do something about it. It wasn't until I took these photos that I noticed a plastic/nylon bush and it displays that replacement may fix all my issues.
So the questions are,
1 - Is there a repair kit available to fix this problem?
OR
2 -Do I make some replacement bushes and then out of brass or something similar?
OR
3 - Cut out all the old stuff and drill it oversized and put a high tensile pin through the lot?
So the pics show the offending nylon bush at the bottom and the other slightly unclear pic shows the bottom of the hinge pin which is pressed over and would have to be cut off to get it out.
OR
OR
5 years 6 months ago #196472
Replied by cobbadog on topic Bottom Door Hinge
I forgot to mention that I have a metal lathe and almost the ability to make pins and bushes but I am in a "learning" mode but enjoying it and have a lot of patience. :woohoo: :evil:
- Thank you received: 1174
5 years 6 months ago #196475
by Southbound
Replied by Southbound on topic Bottom Door Hinge
Give HIM a call as they are available new, non genuine.
www.himspares.com.au/products/isuzu
5 years 6 months ago #196476
by fxs80
1939 D2
Replied by fxs80 on topic Bottom Door Hinge
Found a set of useable ones for my 38 D2 Inter on fleabay the pins are similar with brass bushes, just had to ream slightly
1939 D2
- Thank you received: 546
5 years 6 months ago #196480
Replied by Blackduck59 on topic Bottom Door Hinge
Ford F series used similar
5 years 6 months ago #196493
Hi Gents,
thank you for the replies and the tip about HIM spares will follow up on that.
5 years 6 months ago #196534
So far I have sent internet enquiries to them but no reply as yet. I'll give them until mid next week and then ring them if I need to.
5 years 6 months ago #196535
by wee-allis
Replied by wee-allis on topic Bottom Door Hinge
Hi Cobba,
You can try BRETTS Spares in Wyong for all your Hino bits. Great to deal with and if they don't have the parts in stock, they usually get genuine parts overnight and direct to you.
5 years 6 months ago - 5 years 6 months ago #196558
Looks like the easy way out is to just buy a new hinge. After looking at the thing the more I thought about it and the complexity of splitting a bush that is pressed into place then ream it out to suit a pin/bolt.
Thank you Steve
Thank you Steve
Last edit: 5 years 6 months ago by cobbadog.
5 years 6 months ago #196602
Checked out 2 suppliers for a new hinge and went with Bretts Parts (HIM). Delivered is $34.00 which is the asking price of the other site then add GST and delivery.
Thanks Steve.
Thanks Steve.
Time to create page: 0.478 seconds
