AR110 build (not for the purists)
12 years 9 months ago #54386
by Coupeute
Replied by Coupeute on topic Re: AR110 build (not for the purists)
Gary, did you have to modify/move spring locators on the axle housing or were they the correct spacing? Just looking to the future.
12 years 9 months ago #54387
by fxs80
1939 D2
Replied by fxs80 on topic Re: AR110 build (not for the purists)
Yep, CM diff is same wheel width but had to cut off orig. ones, made new ones out of 4mm because springs are narrower and re-welded in new position (180`) on other side
1939 D2
12 years 9 months ago #54388
by grahamjb
Replied by grahamjb on topic Re: AR110 build (not for the purists)
Further to the stress cracks that you have on the inner guards I got around the same problem by cutting the affected section out and welding in new steel to follow the curve in the guard. This also provided a solution for the custom radiator that I am fitting to my AR-110. I have a couple of photos on photobucket
s674.photobucket.com/albums/vv101/graham...International%20Ute/
12 years 9 months ago #54389
by Andy Wright
Replied by Andy Wright on topic Re: AR110 build (not for the purists)
Fine work, Gary. Really like your work. Great finish and attention to detail, mate.
12 years 9 months ago #54390
by fxs80
1939 D2
Thanks to Dave (coupeute) I've got front and rear shackles sorted today and also run all the new chassis brake lines.
1939 D2
12 years 9 months ago #54391
by fxs80
1939 D2
Finished off the skirts ready for rubbing back to paint
Gone from this
To this
Test fitted the front - need to do a bit more work on the bonnet though
Gone from this
To this
1939 D2
Time to create page: 0.416 seconds
