- Thank you received: 42
I now own a D1310 HELP
15 years 6 months ago - 15 years 6 months ago #4946
I now own a D1310 HELP was created by
we're now proud owners of a new old truck 79 d1310 345, generally in good order but in need of indicator lenses, maybe brake drums- shoes, steering box, bonnet badge etc. where's the place to go for parts around west of Melb
Last edit: 15 years 6 months ago by Andy Wright.
15 years 6 months ago #4947
by atkipete
Replied by atkipete on topic Re: I know own a D1310 HELP
Welcome to the forum, these parts are pretty common and you should not have too much trouble. If you send a PM ( private message) to a fellow on this forum called Podge 66 he can probably help you but he is on the eastern side of Melb.
That 345 engine is probably a later addition as the D1310 usually came with a 6-281 or 6-282 engine.
15 years 6 months ago #4948
by Andy Wright
Replied by Andy Wright on topic Re: I now own a D1310 HELP
Welcome Legend. Hope you enjoy it here and good luck with the 1310.
15 years 6 months ago #4949
by podge66
Replied by podge66 on topic Re: I now own a D1310 HELP
:)Welcome to the forum and glad to see you bought a good aussie brand truck. Indicator lenses can be bought at Bursons or Repco. In the hella book or Narva . Steering boxes are hard to get a good one, brake shoes get them relined at any brake place, drums machined at brake place if still in size. podge
15 years 6 months ago #4950
Replied by on topic Re: much enjoyment to date
Thanks all, yes having much enjoyment to date. another 1 for ya tho, what about little plastic gromets/sleeve that hold wire like shaft, " connects door mechanism to door latch" also looking for steering wheel, mine has large cracks in it.
15 years 6 months ago #4951
Replied by Sarge on topic Re: I now own a D1310 HELP
steering wheels seem to be expensive to repair comercially, but results can be stunning.
poor chaps like me resort to 2 pack stuff like araldite or some of those maleable fillers that when set can be filed drilled and machined.... there were some reports in the TOMM magazine of these being very sucessul on tractor steering wheels.
Good luck
sarge :-X
Good luck
sarge :-X
15 years 6 months ago - 15 years 6 months ago #4952
by Bono
Replied by Bono on topic Re: I now own a D1310 HELP
hey sarge,
With that, do you need to open up the crack then fill. I tried it with my steering wheel using araldite but the hair lines are still there.
Cheers Bono.
Cheers Bono.
Last edit: 15 years 6 months ago by Bono.
15 years 6 months ago #4953
Replied by on topic Re: I now own a D1310 HELP
Bono, I had a couple of steering wheels done this way and been very successful you must grind out out the cracks then use the 2 pack filler , shape it and finaly paint it hopes this helps . Dave
15 years 6 months ago #4954
by GM Diesel
Replied by GM Diesel on topic Re: I now own a D1310 HELP
Dave,
Do you know the name of the two pack filler ?
Have to give my wheel abit of a tiz up.
Barry
Barry
15 years 6 months ago #4955
by Rookie
Replied by Rookie on topic Re: I now own a D1310 HELP
POR make a product specifically for fixing wheels
www.por15.com/prodinfo.asp?grp=SWRK&dept=11
A cheaper method would be to fill and spray with 2pac.
Steve
Steve
Time to create page: 0.552 seconds
