- Thank you received: 4810
Army acco front axel in C series?
- wedgetail84
- Thank you received: 49
well an 1800 potentially, but I don't even have the truck yet. In fact I'm still waiting on news of when my HVCBA will be! I'd actually be very interested in your gear though, do you think it'd be a good fit? What's the difference in front axle rating betwen a 4wd 1600 and CD1820?What size c line do you want to make a 4wd, l have transfer case and front end from a c1600 4wd. Podge
What are the important differences between 1800 and 1600? I assume chassis thickness, rear axle size and springs... The widths would be the same right?
Can you fit the 1800 spider hubs to the 1600 4wd front axle?
- wedgetail84
content.wisconsinhistory.org/cdm/compoun.../id/36415/show/36353
They are out there.
- wedgetail84
Great link, thanks for that. As william says the D1610 has a front axle rating of 6000lb and 6.17:1. The D1830 has a 7500lb front axle and 6.16:1 rear. So ratios are good but that's quite a hit in the payload department - no worries off road but running it at full GVM on road might not be so good. Not sure what the RTA would think either...I think the C and D had the same specs of 6000lb or 2720kg front axle, although rumour has it that it was actually a Dana 70 front axle which had a Dana rating of 3500kg.
On that link though, I can't find anything in the C line higher than 1300? All the bigger stuff seams to be acco...
- wedgetail84
Yes that's right, but they're not listed in that info link. So I can't find their axle ratios or front axle ratingThe C Lines went up as far as the C1800 in bonneted trucks. This was an 8 tonner but 4x2.
