- Thank you received: 4
Land cruiser steering box
- Thank you received: 15
I would hazard that with even 20 inch rims the 80 or 75 box will be just fine for several reasons -
1. the tyres on your truck will be smaller in diameter than my 38"s, but diameter is insignificant considering you're turning on a pivot axis not a diameter.
2. your tyres will be pumped to a much higher pressure and will likely be narrower than the 13.5" that mine were. Hence a smaller contact patch and ergo less resistance to turning
3. Even though your GVM is higher than my 3ton race truck most of that will be on the back axle.
4. Have a look at the length of the stock steering knuckle arm on the donor vehicle compared to your dodge. A comparatively longer arm on the knuckle will give more leverage to the steering box but will give less steering lock for a given pitman arm throw.
At the end of the day, have a look at the diameter of the sector shaft of the LC box and compare it to the diameter of the original non power steer box you have already. If they're the same diameter, then at least strength and safety factor wise you'll be fine. As for power, you simply have to do the sums and compare the factors i've listed above
Hope this helps.
I've got the truck
Jon
Cheers thanks Paul some great info there sounds like this guy might have a few answers and he thinks out of the box a bit, thing is I don't want to throw on one too light and come around a corner and it crap out on me with a machine on the back, bit of research on it and a few different peoples grey matter on the job always helpsG'day Hemi, unfortunately I didn't do the work. Column looks to be from a from a '45 series. If you're interested to talk to the builder I'll have a word with him and if he's o.k with me passing on his ph #, I'll let you know. He's one extremely knowledgable bloke. Some of the work he did on the D1610, air seats, air cond, tipper, winch, power steer, engine/trans, big single rims, the list goes on. Cheers, Paul.
rock crawler yes i can imagine the old ticker must have jumped a few beats when that broke, yer i can imagine the enormous load that would have been on your truck with those big tires , will throw up a few pics of my steering box location and arm positions, got to sort out this photo bucketAn 80 series will be forward throw and a 75 series will be rear throw on the pitman arm (or vice versa, but for this exact point in time i can't remember which). The 75 series box on my race truck held and turned 38" tyres easily, but eventually snapped the sector shaft in half in the middle of a race when i bound it up against a rock
Hope this helps.
