- Thank you received: 42
Hoo U Gunna Call
6 years 6 months ago #187770
by atkipete
Replied by atkipete on topic Hoo U Gunna Call
93 tonne gross....When is the new Volvo arriving ?
6 years 6 months ago #187773
Replied by Swishy on topic Hoo U Gunna Call
AtkiPete
Gudday m8
NO 'V'Bus here
we need good reliable yanky iron th@ keeps on go n
we offer prompt n reliable service to our customers
th@ B not possible with a 'V'Bus in the ditch on side of rd waitn for parts n service
Gudday m8
NO 'V'Bus here
6 years 6 months ago #187788
Swishy,I Know I'm not the sharpest knife in the draw.
But; I thought you were building the Trailer with 2 rows of 8 ???
Replied by hayseed on topic Hoo U Gunna Call
Swishy wrote: the trailer RSend if n we go with 3x8 @ 3.5 wide with 3.6 O/All spread = 42t
6 years 6 months ago #187792
Hay
Seed
Gudday m8
yes 2x8 witha detachable 1x8 = 3x8
project 1: make it 2x8 ....register n make useable
1.1A : make it x10dable
1.1B: Add 3rd detachable axle (probly with 8 airbags)
all 2 B dun in thiz millinium
ifn u get my drift
Seed
Gudday m8
ifn u get my drift
6 years 6 months ago #187847
by rex
Replied by rex on topic Hoo U Gunna Call
Gentlemen
Dust in Swishy's yard, never going to happen OIL is the magic answer to dust suppression. Swishy has the answer with his Detroits constantly topping up the surface.
Swishy mate question
How long is the bed in the trailer load area from front of rear axle group to base of neck?
Section size of the two beams supporting the deck top and bottom flange and web?
Distance from the centre line of the rear axle group to the most forward king pin.
Really interested or just curious.
Rex
Rex
6 years 6 months ago #187848
ReX
m80
RE: Dust in Swishy's yard
OK
ok
the secret iz out
Y our trailers dun rust
:lol:
:woohoo:
How long is the bed in the trailer load area from front of rear axle group to base of neck? Bout 6500 plus 500 riser ramp 2 RSend
Section size of the two beams supporting the deck top and bottom flange and web? Flange 350 x 20 top n bottom ...... box section beam 350 wide x 320 hi
Distance from the centre line of the rear axle group to the most forward king pin. Bout 12m
I have been scrutinizing the yanks with an extreme scrute
eg: Murray Trailer....Cozad..... Rackleybilt etc
Thanx for your interest
m80
OK
ok
the secret iz out
:lol:
:woohoo:
6 years 6 months ago #188493
Wen on the rd
it interrupts yard duties
:lol:
max n out on height @ 5m
get n the height down Height of mast on the ground 4.7m ........... loaded Height 4.95m
Now
Back 2 yard duties
:lol:
Now
Back 2 yard duties
The following user(s) said Thank You: craig308
6 years 6 months ago #188522
by rex
Swishy mate
Based on the dimensions it appears that if yo have the following ......
distance pin to centre of axle group 12.00 metres
possible axle weight rear group 31.00 tonnes
possible gross weight at pin with dolly 45.00 tonnes
we have a total gross of 76.00 tonnes forgetting the steer
allowing for say 6.00 tonnes tare weight rear axles trailer
and taking 4.00 tonnes trailer 9.50 tonnes dolly and rear of truck total at front = 13.50
total tare weight at front.
lets say then we have a tare weight of 19.50 tonnes and a gross weight of 76.00 tonnes gives a possible payload of 56.50 tonne.
if I calculate the available payload and assuming my tare weights are reasonable the answer is something like this.
load "L" = 56.50
distance from centre of rear axle to load centre of gravity "B" = 6.70 metres
distance from centre of rear axle group to turntable pin "D" 12.00 metres
L X B / D
56.50 X 6.70 / 12.00 = 24.96
unless i am completely wrong this puts the centre of gravity somewhere around 1.80 metres from the start of the goose neck
Rex
load "L" = 56.50
L X B / D
Rex
6 years 6 months ago #188543
ReX
Gudday m8
RE:
possible axle weight rear group 31.00 tonnes ... yup as 2x8 n az a 3x8 Rsend = 42t @ 3.5 wide
possible gross weight at pin with dolly 45.00 tonnes.... yes ... with the 2x8 dolly @ 3.5 wide
also with a close cuple 1x4 dolly = 25t ,,, & a 1x8 long spread dolly 31t
lets say then we have a tare weight of 19.50 tonnes and a gross weight of 76.00 tonnes gives a possible payload of 56.50 tonne. ...... yup close enuff I can see why U dun add any for steer az U're 'V'Bus is fully loaded when run n MT on the steers
Your pritty close with your calc but dun 4 get a clip on 1x8 xtra axle on RSend to make it 3x8 @ 3.5 wide
I'll nok out a chart of the guesstimate trailer n dolly doodadd
Gudday m8
RE:
6 years 6 months ago - 6 years 6 months ago #188573
Here U go
A ruff chart me knokd up
Lil squashy try n to get er all on an A4 sheet
sum combinations May B a lil useless ... but by mix n match configurations can B dun
2C + 3C (1 x8 long spread Dolly) looks like valu for money .... where load is bout midships along deck
Last edit: 6 years 6 months ago by Swishy.
Time to create page: 0.649 seconds
