- Thank you received: 599
RTO 609 gearbox ratios
- 180wannabe
4 years 7 months ago #202815
RTO 609 gearbox ratios was created by 180wannabe
Does anyone have the gear ratios of an RTO 609? I have spent hours searching the 'net to no avail.
I'm getting the feeling the 609 was not very common, the only mention of it i have come across has been on forums from the UK, and that was only general comments as people reminisce.
Thanks in advance, Brett.
4 years 7 months ago #202816
Replied by Swishy on topic RTO 609 gearbox ratios
Wanna
gudday m8
if eye read th@ right
U got a R oadranger T win countershaft O verdrive 6 00 ftlb torque capacity 9 speed
probly the 9 speed can have a splitter to make it 13 speed
gudday m8
4 years 7 months ago #202820
Replied by JOHN.K. on topic RTO 609 gearbox ratios
Truck & Bus test specs...1979/80....RTO 609....8.56/6.56/4.65/3.43/2.55/1.91/1.35/1.0/0.74...R.7.66/2.23.
- Thank you received: 839
4 years 7 months ago - 4 years 7 months ago #202821
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic RTO 609 gearbox ratios
.Have a bo peep at this ...................Mind boggling, but may be on the missing list,...……..
www.roadranger.com/rr/ProductsServices/P...smissions/PCT_486870
...............……..Billy...……………...
Last edit: 4 years 7 months ago by BillyP.
- 180wannabe
4 years 7 months ago #202822
Replied by 180wannabe on topic RTO 609 gearbox ratios
Yes Swishy, that's what it is, though i don't know if a splitter was available for the 600 series. I think the 13 speed of the 600 series was all stick shifts.
John.K. and BillyP, thank you both for your trouble, very helpful.
I have two gearbox and two diff options available to me for my V8 petrol tilt cab acco, so i am beginning to work out the best option, but i just couldn't find anything on the 609.
4 years 7 months ago - 4 years 7 months ago #202824
by BillyP
.This probably comes under the heading of useless information ….but..... early days at Alltrans / Zacuba, the Cameranians
had RT 613 boxes . single stick with a 3 position gear knob. worked similar to a 15 speed. only all on the top of the stick.
(note that the pic is of an RTO 613 )
……………….Billy...…………….
4 years 7 months ago #202828
by Brocky45
Replied by Brocky45 on topic RTO 609 gearbox ratios
I have an RT 613 sitting in the shed attached to a 555 Cummins. Man I bought them from said it was an underdrive splitter.. Came out of an bitumen sprayer truck.
4 years 7 months ago #202833
The 613 is quite different from all the bigger boxes.....the 613 is actually a 615......ie a 5x3........and unlike the bigger boxes ,the front gears cant just be swapped around to get an overdrive.....in fact the whole front "set" ,six gears ,shifter dog ,etc ,was f/n dear ...like $600 in 1975..........there is no splitter for the 613,howver ,gear tooth forms and profiles were changed around over the years,meaning interchanging bits is problematic.............the 613 was a great box for brick & concrete trucks ,as it had the lowest low ratio of any of the boxes....18 to 1........thats a bog gear.
- Thank you received: 546
4 years 7 months ago #202834
Replied by Blackduck59 on topic RTO 609 gearbox ratios
Same shift pattern as the RTO610, has the odd 6-7 shift.
Like the OD ratio on that, my 610 only has .8 and would like a little more OD. May have to do some digging.
4 years 7 months ago #202836
I think a RTO 609 would be a good box for a classic truck ,thats driven unloaded............no point having stump puller lows,better having usable higher gears..............the ultimate in overdrives is the RTOO 913,/9513....50% OD.......these were fitted to some Hippos to get up the 30mph diffs into a saleable roadspeed..........2000 engine revs to 3000 tailshaft revs........better have a very short tailshaft tho,or you will blow it up......as Ive seen done on some Leylands let to coast downhill.
Time to create page: 0.505 seconds
