Modern tacho alternator driven
4 years 2 weeks ago - 4 years 2 weeks ago #208297
Replied by Lang on topic Modern tacho alternator driven
No eBay APP ID and/or Cert ID defined in Kunena configurationWould you not need an adjustment on the tacho to cater for different pulleys on different engines? A jump wire added to an ordinary alternator to give you the "R" output will probably be a fixed (and most likely wrong) signal. I know I had to get an adjustable one for my Perkins Commer. I had to lay under the truck with a laser tacho tracking a white line drawn on the crank pulley while my mate screwed the adjuster on the back of the tacho to match with the correct speed.
Last edit: 4 years 2 weeks ago by Lang.
- Rattail 1927
- Thank you received: 66
4 years 2 weeks ago - 4 years 2 weeks ago #208301
by Rattail 1927
Replied by Rattail 1927 on topic Modern tacho alternator driven
In setup mode , the tacho has a 10-300 adjustable setting so there is a little bit of guessing on my part , I couldn’t get into the setupMode,because there was no signal I know the 2 rubber plugs are for adjust it and change background light , I’m currently studying Chinese so I can read the instructions !
Last edit: 4 years 2 weeks ago by Rattail 1927. Reason: Information
Time to create page: 0.403 seconds
