- Thank you received: 66
Charcoal burner on trucks ?
- Rattail 1927
3 years 8 months ago #212239
by Rattail 1927
Charcoal burner on trucks ? was created by Rattail 1927
3 years 8 months ago #212241
Replied by bparo on topic Charcoal burner on trucks ?
the idea was you burnt charcoal in them and the gas given off was used as the fuel source for the motor instead of petrol. I saw one in action at Lake Goldsmith feeding a stationary motor once but people told me that they were almost impossible to keep running correctly on a moving vehicle as the motion upset the quality of the gas coming out of them. They were mainly used during the war when petrol was in short supply
3 years 8 months ago #212242
Replied by Lang on topic Charcoal burner on trucks ?
They normally had to get going on petrol to warm up to run properly. I believe, if set up correctly, they were OK but considerably reduced power. Some vehicles had large gas bags on the roof to overcome variations in use-as-you-go production.
There is a lot about them on the web and quite a bit on the forum if you can find it.
lang
lang
3 years 8 months ago #212243
Replied by mammoth on topic Charcoal burner on trucks ?
It was old technology, called "producer gas". Quite a few power stations were run on producer gas from 1920's until diesel took over. It is actually raw wood that is fed into a retort with only just enough air to keep it going but not enough to burn the gas given off. Next time you are in front of a wood fire you will see the coals burning but then a gap and then the gas above providing the flames. The quality of the gas depended on how well it was "scrubbed' meaning ash and other impurities filtered out. I believe there will be plans for home built ones on the web.
3 years 8 months ago #212244
If you want to know ALL about it read this. Looks technical but it is a very interesting bit of Australian history.
consuleng.com.au/Producer%20Gas%20&%20th...torist%201939-45.pdf
3 years 8 months ago #212248
by Zuffen
Replied by Zuffen on topic Charcoal burner on trucks ?
Interesting read Lang.
I remember my Parents talking about gas producers in use during the War.
As a side note the article mentioned the road death toll in Victoria being 421 in 1941 with a bulge in the 18-21 age group. not much changes.
3 years 8 months ago #212251
Replied by hayseed on topic Charcoal burner on trucks ?
My Grandfather had one on a IH W30 Tractor during the War,He had to put Low Compression Pistons In It.After the War he put the Standard Pistons & liners back in It..
I have the Low compression Pistons rings & Liners in their Original Packing Crate in My Shed..
- Thank you received: 4586
3 years 8 months ago #212252
Replied by Mrsmackpaul on topic Charcoal burner on trucks ?
The Tomm's magazine ran a series of articles some years ago (10 or more years) and wood gas was been used to run outback power houses
I have no idea what size but from the photos in articles they were very large low reving type motors and I seem to remember these ran well into the 50's or maybe even 60's
Perhaps someone on here knows of the article and could scan it and post it for us to read including me as it was very interesting
I remember I photo copied it for my father who was always into power generation
- Rattail 1927
3 years 8 months ago - 3 years 8 months ago #212274
by Rattail 1927
Replied by Rattail 1927 on topic Charcoal burner on trucks ?
Thanks guys I’ve got a ides now , I imagine if they were hard to keep going it must have been a nightmare to get started , people are ingenious when they need to be aren’t they, it obviously was a last resort I imagine otherwise everyone would be still using it ? And are briquettes charcoal, ? I remember when I was about 11 or 12 lighting the hot wAter heater and using briquettes to run it... in the mid 80’s when gas was being put on cars but everyone never thought about gas on trucks , a guy I know was carting milk from Deniliquin to Sydney twice or 3 times a week as a driver and I don’t know how it came to be but he had a couple of 9kg bottles of lpg and had a micro switch on the loud pedal and it injected a small amount of gas but apparently he reckoned it gained 100 hp .. this was in a bonneted Mack super liner I’ve no idea how much gas it injected but I assume it wouldn’t be much ,1 or 2 psi .I never seen the setup I had past it a number of times but was totally unaware of what it had going on .. I’d do it to the Acco and probably blow the intake manifold and carby clean off it ...
Last edit: 3 years 8 months ago by Rattail 1927.
Time to create page: 0.622 seconds
