- Thank you received: 49
Eaton no 4 and tubeless tyres
1 year 3 months ago #242962
by ashmenz0
Eaton no 4 and tubeless tyres was created by ashmenz0
Hi All
Does anyone have an Eaton no 4 diff and running 22.5"tubeless tyres?
Ash
Ash
1 year 3 months ago #242967
Replied by JOHN.K. on topic Eaton no 4 and tubeless tyres
Tubeless have the same rolling radius as tube tyres........I assume you have a spider wheel.......tubeless rims simply fit on without any modification..........if you have 10 stud english type ,then the mod required to fit ISO 10 stud was talked about here a while ago.
1 year 3 months ago - 1 year 3 months ago #242968
by ashmenz0
Replied by ashmenz0 on topic Eaton no 4 and tubeless tyres
Hi John
I've sourced some new 22.5" rims for the front thanks to jon_d's recommendation of Oceanic Direct. I just need to check the different offset clears everything.
Yes, I have 5 stud spiders.
I asked the supplier can he supply 22.5" rims for my No 4 Eaton arse end (currently 20" rims) and he tells me that he can, same hub and spacer. I can't get my head around how this rim will sit where the 20" one does and have 22.5" tyres on it.
Am I going mad?
Ash
Am I going mad?
Ash
Last edit: 1 year 3 months ago by ashmenz0.
1 year 3 months ago - 1 year 3 months ago #242970
Replied by mammoth on topic Eaton no 4 and tubeless tyres
Ash, The tubeless tyres have a lower profile (or aspect ratio) than tube type so for a larger diameter rim you end up with the same outside tyre diameter. Obviously 11R is 1" wider than 10.00R tube radials. The tubeless rims are pretty well standard at 8.25" wide for 11R but in the early days of tubeless 7.5" was not uncommon.
Last edit: 1 year 3 months ago by mammoth.
- Thank you received: 600
1 year 3 months ago #242972
Replied by 180wannabe on topic Eaton no 4 and tubeless tyres
Hi Ash, i think you will find an 11R22.5 will be about the same size and shape as a 10.00x20. The tubeless rims are of course larger being 22.5", but the rims to suit spider hubs have a "centre" (for want of a better word) welded into them so that they mount up to a spider hub just the same as a 20" tube type rim does.
Maybe google up some photos of trucks with tubeless steer tyres, and you will see the difference compared with when the rim is around the other way when on the drive outer. The "centre" is easier to see when on the steer, you should see a small gap between the "centre" and the rim, which should make sense once you see it.
Brett.
Brett.
1 year 3 months ago #242973
Ash, the Adapter ring that clamps to your Hub is 20" diameter , whilst the Rim Itself is 22.5" diameter..
Replied by hayseed on topic Eaton no 4 and tubeless tyres
Am I going mad?
Ash
1 year 3 months ago #242977
Similar deal when fitting 17.5" tubeless spiders to hubs previously carrying 15" tube type.
1 year 3 months ago #242980
by wouldyou
Replied by wouldyou on topic Eaton no 4 and tubeless tyres
That well base centre allows you to place the bead in there to get the tyre over the rim.
David.
David.
1 year 3 months ago #242986
Replied by cobbadog on topic Eaton no 4 and tubeless tyres
When 22.5" rims first came to Oz our wheel shop decided to get on the band wagon and import Lemmertz rims first then went over to Michelins. At that stage adapters were not common so they had a company called Loadarm at Kurnell roll 30mm square bar to suit the rims and they welded them fully in place then machined the tapers in place. Yes different offsets were available.
The following user(s) said Thank You: ashmenz0, 180wannabe
1 year 3 months ago #242988
Replied by Swishy on topic Eaton no 4 and tubeless tyres
Time to create page: 0.441 seconds
