Fuel pump kit
- jumpstart231
I'm new to this, hopefully someone can help.
I have a 1962 AB 160 / WB 153 the engine number is
AGD 26420490 I believe it's 281 ci 6 cyl. I'm after a
fuel pump kit to rebuild it. I'm not sure were to get one from. Can anyone lead me in right direction?
From the engine number I can tell you it was cast in the Geelong Tractor Factory (A = Australian) and it is a Gold Diamond motor.
After that I am out of knowledge!
- jumpstart231
Thank you very much that that helps heepsG'day,
Most autoshops like Repco, Bursons etc should be able to order one if for you. Goss still make kits for your model (see application chart below)..
I think your engine may be a 264ci, not 281ci (according to the prefix of the engine number you supplied)
-Stu
- jumpstart231
going from the engine number I would expect the engine to be a 264 not a 281. the 3 digits after the letters in the engine number signify the size, in cubic inches, of when the motor left the factory.
Thanks heeps . Very interesting
