- Thank you received: 4
Bogie drive two speed diffs
12 years 6 months ago #67248
by oldfulla
Bogie drive two speed diffs was created by oldfulla
All
Does anyone remember what model trucks that used 2 speed Eaton diffs in their bogie drive options.
The ones I'm talking about were set up in a fashion that it was recommended (by the manafacturer) to split the diffs separatly so as to gain 3 different diff ratios.
I recall such beasts - where the 'diff changing' instructions (plate on dash) engouraged the following process.
Set both diffs in low range, move off and then change one into high range, and then the other up to high. Do a stick shift, and drop both back to low range - and repeat the above process.
I think the vehicle I saw this in was an IH Loadstar.
Anyone else remember these?
Oldfulla
Oldfulla
12 years 6 months ago #67249
Replied by hayseed on topic Re: Bogie drive two speed diffs
G'Day Oldfulla,
mate I can remember as a kid at the local wheat silo. Where everyone was standing 'round a (then) new bedford And everyone was talking 'bout the 2speed bogie drive.
That's the only one I've ever seen........
12 years 6 months ago #67250
by atkipete
Replied by atkipete on topic Re: Bogie drive two speed diffs
Have heard of this setup but never seen one. You would presumably have two red buttons on the stick.
12 years 6 months ago #67251
by ronhorse
anything above the reasoning of a mongrel dog is a waste of time
Replied by ronhorse on topic Re: Bogie drive two speed diffs
The only bogie drives with two 2 speed Eaton diffs that I have seen were in the Ford Thorntons used on the Murranji Track in the 40's-50's
12 years 6 months ago #67252
Replied by bigcam on topic Re: Bogie drive two speed diffs
Pete, I've never actually seen one, but I've seen an ad for one in an old commercial car magazine. The shift knob was like a 13 speed knob and was air.
12 years 6 months ago #67253
by The Learner
You learn something new every day
Replied by The Learner on topic Re: Bogie drive two speed diffs
12 years 6 months ago #67254
Ok
YES I have air operated 2 speed in the SAR
Tiz a set n 4 get
Reason: When we ordered the beast way back when the KW mob were not happy with the 2 speed diff set up coz they had a few failures with trucks on road train work, mainly from shiftn the 2 speed on the run ( one diff would change the other wouldn't) so we suggested to mount the switch outside the cab n th@'z where it tiz 2day
the 3 speed I've never seen but heard about twaz a tandem drive 2speed diff with the diffs either in low or high or intermediate by runn n one diff in hi n the other in low where by the interaxle diff would really do n a lot of work in splitn the 2 speeds, the controls were like the RR13 speed jamtin top with 3 positions.
Me thinks they were an option on trucks from the 60's for short wheelbase beasts as 2 stik cogboxes were to long
[ch9786]
Replied by Swishy on topic Re: Bogie drive two speed diffs
Ok
Tiz a set n 4 get
[ch9786]
12 years 6 months ago #67255
From what I can remember,
The bedford had just one red button on the gearstick. You drove it just like any other two speed Diff.
Completely different animal to the Dual range eatons that Swishy has!!!!
Like swishy said they're set & forget......
12 years 6 months ago #67256
by olddon
Replied by olddon on topic Re: Bogie drive two speed diffs
Back in the late 60''s I drove a Commer Knocker that had an Eaton two speed set up on a bogie drive,and it seemed to work ok.They were No4's from memory
12 years 6 months ago - 12 years 6 months ago #67257
by Dodge fred
Replied by Dodge fred on topic Re: Bogie drive two speed diffs
Last edit: 12 years 6 months ago by Dodge fred.
Time to create page: 0.473 seconds
