- Thank you received: 42
Help on ACCO model numbers
11 years 10 months ago #87220
by atkipete
Replied by atkipete on topic Re: Help on ACCO model numbers
I think there was a system but it ended up all confused;
10, 20 and 40 were petrol - the higher the number the bigger engine ( now you could option a diesel engine on these models BUT the type number wasn't changed)
30, 50 and 70 all referred to diesels, the higher the number the better the engine and the first ACCO to earn the 70 suffix was the 3070A with 903 Cummins.
Thats my theory anyhow and someone out there may know more.
11 years 10 months ago - 11 years 10 months ago #87221
by V8Ian
Replied by V8Ian on topic Re: Help on ACCO model numbers
I should have clarified, my comments re model numbers, it applied only to ACCO A.s and later. I was told this in the schoolyard when the ACCO A was released, don't stake your first born's life on it.
Atkipete, as the trucks got bigger, so did the model number, so why was the 3070's successor a 2670? Could it be IH were emulating its European counterparts, with the 26 indicating the GVW?
Last edit: 11 years 10 months ago by V8Ian.
11 years 10 months ago #87222
Replied by bigcam on topic Re: Help on ACCO model numbers
These are a few ACCO numbers I remember-
1810 A (and V8 petrol about an 8 tonner
1830 A (and Deisel usually Nuess about an 8 tonner
1950 A V8 Nuess Diesel 6 X 4 and 8 X 4
2150 A (and 555 Cummins 6 X 4
2152 A (and 555 Cummins 8 X 4
3070 A (and 903 Cummins 4 X 2, 6 X 4
3072 A (and 903 Cummins 8 X 4
3074 A (and 903 Cummins 6 X 4 with 44,000 lb diffs either Rockwell or Eaton.
1950 C VT 190 Cummins 4 X 2 and 6 X 4
2250 D DT 466 Inter motor 6 X 4 and 8 X 4
2350 E (and G) Cummins C series 4 X 2, 6 X 4 and 8 X 4
11 years 10 months ago - 11 years 10 months ago #87223
by kenny-mopar
Replied by kenny-mopar on topic Re: Help on ACCO model numbers
most acco 1830c series i have seen have the mighty perkins with a s cam sort of braking system usually a slightly higher GVM (than the 1830B which have "wedge" type brakes)somewhere around 14030kgs from memory
cheers ken
however this one proves my "mostly perkins powered" theory partly incorrect
www.farmmachinerysales.com.au/buy/detail...8&__sid=138242167786
cheers ken
Last edit: 11 years 10 months ago by kenny-mopar.
11 years 10 months ago #87224
by FatBob103
Life is to short to drink cheap wine. On the other hand I plan to live forever - So far so goo
Replied by FatBob103 on topic Re: Help on ACCO model numbers
I have no idea of the numbering lettering but this is an ACCO 1950D which I sold two months ago for $15,000
11 years 10 months ago #87225
by John Whale
Replied by John Whale on topic Re: Help on ACCO model numbers
hello all i had a 1982 acco 1830 c with a perkins it had a 5 speed with a 2 speed diff and full air with a 6 spoke front end most i saw were 5 spoke ( i think) regards whale
11 years 10 months ago #87226
by atkipete
I dont think so, the 2670 was available in 4x2 6x4 and 8x4 form, all with different GVMs
I why was the 3070's successor a 2670? Could it be IH were emulating its European counterparts, with the 26 indicating the GVW?
11 years 10 months ago #87227
by V8Ian
Hmmm, a minor fact that I overlooked.
Thanks.
Thanks.
11 years 10 months ago #87228
by atkipete
There might have been a system once ie the second digit indicating the payload ;
AL 110 a one tonner - AL 162 a six tonner - L180 an eight tonner
but it soon fell apart once they bought more in more models, started adding bogie drives and lazy axles.
The letter in the middle indicates the configuration of the truck ie F is bogie drive and K is 8 wheeler.
11 years 10 months ago #87229
by TIPPER
Replied by TIPPER on topic Re: Help on ACCO model numbers
Hmmm not a very good system then ayyy.
Well have picked up an old girl, 1830b but will start a new thread later with some questions about her.
Thanks for the insight guys.
Matt
Matt
Time to create page: 0.472 seconds
