- Thank you received: 2
Accelerator rubber pad cover for C 1800
13 years 5 months ago #36974
by Tank
Inter Atkinson 4870 as is&&Inter C1840 restored&&Inter AB160 Tipper&&Inter C
Accelerator rubber pad cover for C 1800 was created by Tank
Other than cutting a piece of rubber to stick on the accelerator...has anyone found a suitable sized rubber pad for their C line. Measurments are 1 7/16" by 7 1/2"
13 years 5 months ago #36975
Replied by on topic Re: Accelerator rubber pad cover for C 1800
Hi Tank lot of the old trucks didnt come accelator pad and were just steel . Dave
13 years 5 months ago #36976
by Tank
Replied by Tank on topic Re: Accelerator rubber pad cover for C 1800
Dave, we have to put a rubber pad on the accelerator for a road worthy. Most of the other accelerators we scavanged when looking for parts around the traps had the remnants of rubber stuck to them.
13 years 5 months ago #36977
by scratcha
Replied by scratcha on topic Re: Accelerator rubber pad cover for C 1800
www.clarkrubber.com.au/matting-and-flooring/tiles.html
, what about this gear, I had a look, Bill Thompson Auto doesn't list inter stuff, but may be worth a call.
Stupid Question (im allowed 1 per day) can you buy them new?
13 years 5 months ago - 13 years 5 months ago #36978
Tank
GuddayM8
If U dont wont original
but sumthing to pass a roadworthy
Grap a bit of thik rubber like conveyor belting
Cut to desired size
Dress edge with grinder
Use cut off wheel to cut shallow lines in length of said Go Pedal rubber (neatness scores hi here)
drill 2 holes top n bottom thru rubber n gas pedal
Use a broard head pop rivet with a HD urethane type goo/glu B tween rubber n steel
Wait 24 Hours or a few beers = jobz dun
ButEyeDoSt&2BCorrected
Bettr than New
[ch9787]
Replied by Swishy on topic Re: Accelerator rubber pad cover for C 1800
Tank
GuddayM8
Cut to desired size
Bettr than New
[ch9787]
Last edit: 13 years 5 months ago by Swishy.
13 years 5 months ago #36979
by Tank
Well Scratcha, you can buy new pad rubbers but they all vary in size...I've googled..and none of them give you dimensions, only which vehicle they suit...I thought someone may have come across one that suits the dimensions for their own Inter truck. Clark rubber are my last resort but I will look at the fella you suggested...thanks
13 years 5 months ago #36980
by Tank
Swisha...yes that will be my last option...time is always the enemy!!!...thanks
13 years 5 months ago #36981
by damo
Replied by damo on topic Re: Accelerator rubber pad cover for C 1800
hi tank theres a guy on ebay selling new old stock accelerator rubber pads for dodge at4/d5n it may be the same one your after , it has to bolts holding it to the floor and a channal under the rubber sits on metal accelerator rod, go to ebay and type in at4 and you will find it cheers damo
13 years 5 months ago #36982
Replied by Sarge on topic Re: Accelerator rubber pad cover for C 1800
Tank, my ACCO has what I remember as the same pedal as my previous C1300 had, and looks very similar to my old HJ Holden, bottom hinge to floor... the whole Holden pedal may interchange or just go straight on top of what ever you have got left....
Clark Rubber sell checker plate rubber (I did my whole floor in it) and with a bit of the old GOA adhesive (The one you sniff in a bag) should be good as new.
good luck
/me
good luck
/me
