- Thank you received: 51
Re Rhodes Ridley
9 years 4 months ago - 9 years 4 months ago #152211
by geoffa
Replied by geoffa on topic Re: Re Rhodes Ridley
I was lucky enough to be given a private viewing of the Rhodes Ridley at the Rhodes premises in Mackay St. Kewdale, Perth on 30 September 2003. Mr Bill McConnell generously invited me to come and a look at the truck. He could not do enough for me making me very welcome and telling me all about the truck. I took a number of photos. I have seen a lot of photos of the truck on various websites on the internet but I have not seen any photos of the engines.
As you will see in my photos there are two sets of instruments and controls on the dashboard, one for each engine. I believe the chassis was fabricated from five/eighths of an inch thick plate and measures 16 inches deep by 4 inches wide. I think it is box section. You will also notice that the truck is left hand drive.
[/img]
[/img]
Last edit: 9 years 4 months ago by geoffa.
9 years 4 months ago #152212
by dieseldog
I think you'll find its a redundancy thing- if one engine fails in the field, you could disengage the clutch on that one and keep going on the other.
Replied by dieseldog on topic Re: Re Rhodes Ridley
Well now
th@ now sounds interest n
start one Screemer
n wen happy in run n
engage clutches ..... to drive n start tuther motor
am eye close or no cigar
9 years 4 months ago #152213
Replied by Morris on topic Re: Re Rhodes Ridley
I believe that it was only the FANS that ran in opposite directions (because of the way the fan drive was set up) the motors both ran in the same direction.
These twin GM's were used in General Grant tanks and a few other USA military applications. The twin motor setup was known as a Power Pack.
Morris.
Morris.
9 years 4 months ago #152214
by jeffo
Replied by jeffo on topic Re: Re Rhodes Ridley
From Geoffa's photo, you can see both fans run counterclockwise.
I read that not only were these things paralleled up (400hp), GM also offered the twins mounted in line as well, that's 4-6/71's.
Imagine the racket at full noise.
9 years 4 months ago #152215
by dieseldog
I think what is confusing everybody is the fact that one engine is back to front because there is no room for a blower between the two. So technically, one engine block is turned around and the crank is turning backwards in relation to the block of that engine.
The gearcase has a gear driven from each engine, and the they need to both turn the same way to drive the PTO shaft. If the engines were turning opposite directions, they would need a forth, idler, gear positioned between one engine and the PTO.
- Thank you received: 546
9 years 4 months ago - 9 years 4 months ago #152216
Replied by Blackduck59 on topic Re: Re Rhodes Ridley
Have run a couple of these twin 6's on compressors and mudpumps. Sods of things to get the tune balanced.
Have also seen one setup with torque converters
Believe they also came in a quad version. Those tanks had some interesting drive set ups depending on which company made them, Hard to imagine the noise and heat inside one of them.
The ones we had only had 1 starter (air or donkey engine) and you would start one then start the other using the clutches as said above
Last edit: 9 years 4 months ago by Blackduck59.
9 years 4 months ago #152217
Replied by bparo on topic Re: Re Rhodes Ridley
These ran twin 6-71's driving a common generator for the electric traction motors. I wonder if the Detroits are the same setup
DERM 63 at Daylesford
bparo2003
, on Flickr
a 6-71 GM diesel in the engine room
bparo2003
, on Flickr
9 years 4 months ago - 9 years 4 months ago #152218
by greenie
Replied by greenie on topic Re: Re Rhodes Ridley
Something bad wrong with that last photo of the GM fitted into that rail-motor
WHERE'S the bloody OIL LEAKS ?
9 years 4 months ago #152219
Going by the clutch levers I would say yes.
Time to create page: 0.491 seconds
