8 stud tubeless rims to suit 1973 Denning
2 years 3 months ago - 2 years 3 months ago #242198 by Lang
I put Ford F350 8 stud alloys on my OKA. The Ford tapers were different to the OKA wheel tapers. The local engineering shop retapered them to fit OKA nuts while I waited for $15 per wheel. (So as I could still use the original OKA heavy steel wheels as spares)
Last edit: 2 years 3 months ago by Lang.
2 years 3 months ago #242364 by ashmenz0
Hi Cobba
When the tyres were fitted the put 100psi in them. After driving for a while they reached 130psi.
I lowered them to 90psi the next day and they reached 120psi.
I now start off at about 85psi and they still get to 110psi+
Wheel alignment was done a short time ago.
Ash
2 years 3 months ago #242365 by ashmenz0
Thanks Paul
As soon as I can source the right rims I'm going tubeless for sure.
Regards
Ash
2 years 3 months ago #242368 by ashmenz0
Hi jon_d
I'll let yo know.
Ash
2 years 3 months ago #242373 by V8Ian
Are you checking the pressures with the same gauge, is it a good quality tool?
Those increases are abnormally high. I'd be checking that the brakes aren't dragging and the bearings are properly lubricated.
2 years 3 months ago #242374 by jon_d
There is a standard formula to determine air pressure in a tyre. It requires you knowing the weight on each axle.
Find the maximum cold tyre pressure (written on the tyre) and divide it by the maximum load of the tyre (also usually written on the tyre - noting whether is a single tyre or dual tyre).
Then multiply it by the weight of the axle and divide by the number of wheels on the axle.
Maximum cold tyre pressure (written on the tyre) / the maximum load of the tyre * the weight of the axle / number of wheels on the axle. = suggested air pressure.
The following user(s) said Thank You: ashmenz0, cobbadog
2 years 3 months ago #242377 by JOHN.K.
When I was at the sandblasters ,the labourers there would regularly fill their tyres from the air system......then they'd say how the car was driving funny.......with 125psi in the tyres.............some of them had bicycles ,and would regularly have bike tyres explode .....and wheel barrow tyres ......who da thunk a Chinese wheelbarrow tyre wouldnt take 125psi...........between shifts ,the air would creep up to 150psi ,and all the safety valves dribble.
2 years 3 months ago #242378 by JOHN.K.
I also recall being told "never bleed air from a hot tire"
2 years 3 months ago #242382 by cobbadog
It does sound as if as suggested a dodgy gauge or a mechanical issue causing those variances.
2 years 3 months ago #242383 by Lang
Here are the 4 laws controlling the situation (to get the pressure/volume/temperature relationship.
This first one is a good starter and refers to the others.
Boyles Law
Charles Law
Gay-Lussac's Law
Avigadros Law deals with hypothetical "Ideal Gas" and should not worry our brains.
The following user(s) said Thank You: ashmenz0, PaulFH
Time to create page: 0.266 seconds
