- Thank you received: 3002
Langs next Normandy project - 40's Chev
1 year 3 months ago #242548
Replied by cobbadog on topic Langs next Normandy project - 40's Chev
What model Toyota wheels did you use Lang? Hopefully off the Hilux or Landcruiser as they are both rear wheel drive.
1 year 3 months ago #242549
Replied by Lang on topic Langs next Normandy project - 40's Chev
Hilux 2wd are good because only an inch wider but any 6 stud Toyota and Nissan commercial will fit. Obviously you have to make some arrangements for the hub caps.
I kept the original Chev wheels on the car and the 7.00-16 did not look too pinched in.
1 year 3 months ago #242554
by Pierre
Pierre
Replied by Pierre on topic Langs next Normandy project - 40's Chev
Hi Lang, great little project.
Is it currently in primer or is that a military desert shade already?
Pierre
Pierre
Pierre
1 year 3 months ago #242555
1 year 3 months ago #242571
1 year 3 months ago - 1 year 3 months ago #242572
by wee-allis
Replied by wee-allis on topic Langs next Normandy project - 40's Chev
Lang, to me it's something some very clever old bugger dreamt up, made himself and I for one would have to take the effort to remove it, pull it apart to see how it works and put it all back where it belongs. Love this sort of ingenuity. To hell with the added un-sprung weight.
Last edit: 1 year 3 months ago by wee-allis.
1 year 3 months ago - 1 year 3 months ago #242574
Just found Borg Warner and a couple of others made these torque-tube overdrives in late 30's to mid 50's but they are all conventional round cast boxes not a plate construction. Will have to crawl under for identification numbers and more particularly how they change gears.
The BW and others used solenoids , single lever and two levers under the dash with cables saying high and low
Last edit: 1 year 3 months ago by Lang.
1 year 3 months ago #242575
Replied by hayseed on topic Langs next Normandy project - 40's Chev
I'm with Wee-Allis. Looks a bit Homemade to Me.. Not that there's anything wrong with that!!
I Too, would like to see inside It..
1 year 3 months ago #242576
Sorry boys, a lot more pressing things than pulling that box apart.
Time to create page: 0.592 seconds
