Bedford Identifaction help required.
2 years 8 months ago #245418 by Gryphon
from the mailbox....
Hi there, I hope this email finds you well. I have recently purchased an old Bedford with the idea to restore it. I was wondering if you could help me out with the exact ID of it? I was sold it as a J1, but believe it may be a J2. I have attached a photograph of the two ID plates on the firewall so hope these may help out.
Kind regards
Kris
2 years 8 months ago #245420 by Lang
At an all-up weight of two and a half tons I think the J1 guess may be correct. Singles or duals?
The following user(s) said Thank You: 180wannabe, wee-allis
2 years 8 months ago #245428 by Morris
Thye body plate says it is a TJ.
2 years 8 months ago #245429 by 180wannabe
I think T = truck, and J = series.
It seems Kris is trying to identify what size J series he has.
I can't quite make out if the spec plate says 2t - 10 cwt, or 2t - 18cwt? As Lang suggests, knowing if it has singles or duals might give a strong indication.
2 years 8 months ago - 2 years 8 months ago #245432 by Lang
Certainly looks more and more like a J1
T+B magazine 1972 gives chassis weight of 3768 or 3836lbs ( might depend on tyres fitted ) and GVM of 6496 or 7480lbs . They were described as a 30cwt (1 1/2 ton).
If it has these disc wheels it is a cert to put money on a J1
Last edit: 2 years 8 months ago by Lang.
2 years 8 months ago #245433 by PDU
The wheels are the best way of determining it Lang, as you said before J1 - singles, J2 - duals. ;)
Over two ton it's gotta be a J2.
Time to create page: 0.301 seconds
