- Thank you received: 3
QLD state library
11 years 6 months ago #95841
by morrisguy
QLD state library was created by morrisguy
Hi
The QLD state library has a great on line website. You can peruse many pics of trucks , 1940's and earlier
Mike
Mike
11 years 6 months ago #95842
by morrisguy
Replied by morrisguy on topic Re: QLD state library
I'm searching for the site .
I found this : Commonwealth of Aust. reg . The GMC would be a rarity here I would think
www.archivessearch.qld.gov.au/Image/Digi...w.aspx?ImageId=14123
11 years 6 months ago #95843
Replied by Lang on topic Re: QLD state library
Interesting truck. Commonwealth registration, four wheel drive. Looks like a remote tyre inflation system.
At the law courts - what about a specialist high security (armoured) prisoner wagon imported directly for the job?
11 years 6 months ago #95844
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic Re: QLD state library
IIRC, the D in ZDA indicated Defense Department.
The S on ZSU was Dept of Supply, which covered a number of agencies.
11 years 6 months ago - 11 years 6 months ago #95845
Replied by bigcam on topic Re: QLD state library
Hi Lang, the only thing that about the GMC that doesn't make it look like a paddy wagon (or to use the Brisbane term, Herschal st express) is that you can see out through the back window. My experience with paddy wagons is that the drivers compartment is definatly seperate from the rear bit.
Looks RHD and with a search light and 2 rotators it has that law enforcment look about it, perhaps MP's? ( and Lang, as much as I have limited experience with paddy wagon's, you may know a bit more about MP's? LOL.)
Would have been a very flash bit of gear back in the day. The HD Holden wagon, is it an XR Falcon? and Hillman Imp all of them look new. A heap of pipe beside the Inter as well that looks a bit out of place.
http://www.archivessearch.qld.gov.au/Image/DigitalImageDisplay.ashx?ImageId=14123
Last edit: 11 years 6 months ago by bigcam.
11 years 6 months ago #95846
by oldbob70
Replied by oldbob70 on topic Re: QLD state library
G`Day
could they have been some of the vehicle`s used on the Australian inland survey in the 60`s ???
Oldbob70
Oldbob70
11 years 6 months ago #95847
by tim
Replied by tim on topic Re: QLD state library
Bigcam, well spotted with the Hillman Imp mate. Yes it's an XR Falcon, can't quite read the badge on the boot but it may be a Fairmont. Cheers Tim
11 years 6 months ago #95848
Oldbob, I think you might be closer than us. Maybe the fitting on the front wheel is a very accurate distance measuring device - it does not seem to be on the other wheels which would be necessary for central inflation. It is in an excellent position to be ripped off and cause them to revert to accurate pacing!
Spotlight and flashing lights might be part of the survey set-up.
Cam, certainly not military (though could be registered to Defence Department because the Army Survey Corps were the people who did all the maps before National Mapping took over)
Wonder where it is now?
11 years 6 months ago #95849
Found the answer. From Mike Cecil (former curator at the War Memorial)
Interesting picture, the GMC is one of 2 Johnson Ground elevation meters that were imported to Australia circa 1964. Nat Map operated one and Royal Australian Army Survey Corps operated the other.
I can confirm that the picture was taken in the court yard of the (circa turn of 20th Century) Land Administration Building ( headquarters of the Qld Lands Department for most of 20th Century and also for many years the location of the Queensland Gov
Time to create page: 0.710 seconds
