- Thank you received: 2503
Re: Buzacott 3hp
1 year 6 months ago #249552
Replied by hayseed on topic Re: Buzacott 3hp
I've been wondering about he Gibb Key saga, Cobba..!!
1 year 6 months ago #249558
Replied by cobbadog on topic Re: Buzacott 3hp
I may have skipped a few strps. So the gibb head key gave way when I welded a lump of bar iron along both sides but then made an adapter to screw the bloody big slide hammer directly onto it. I was loosing some power through the link chain, so much so I straighten 3 non quality chinesium links out.
Next I took off the valve cover n removed n machined the valves then lapped them in, made a new gasket n fitted it. Opened the crankcase to find very little crap in the sump so a quick wipe out, new gasket n fitted it. Made a gasket for the fuel mixer n fitted it. Sprayed that new head gadket with copper coat n fitted it up. Could not help myself I had to see if it made noise n it did, straight away. Cleaned the breather out too.
1 year 6 months ago #249559
Started on the fuel tank. Cut the arse out n made a new one. Fitted the fuel outlet n started to tin the tank n patch. Bloody 60 years of dirt takes some cleaning to get the solder to tin the surface, its a work in progress.
Love my LPG soldering iron.
1 year 6 months ago - 1 year 6 months ago #249649
Bought some 25mm angle iron for the tank stand then made a start on trying to age it, this is a works in progress. Then marked out the height for tge inlet n outlet connections which will be soldered i place but have some lock rings on the inside to for a bit of strength with the engine vibrations working away at tgem when running
Last edit: 1 year 6 months ago by cobbadog.
- Thank you received: 786
1 year 6 months ago #249651
Replied by 180wannabe on topic Re: Buzacott 3hp
Thanks for the update Cobba. I really enjoy following your restoration and repair work.
Brett.
Brett.
- Thank you received: 6937
1 year 6 months ago #249688
Replied by Mrsmackpaul on topic Re: Buzacott 3hp
Looking good Cobba
I have seen some pretty average jobs done on 44's over the years for cooling tanks and they seem to hold up amazingly well
Yours looking a bit flash compared to some I have seen
Good work
Good work
1 year 6 months ago - 1 year 6 months ago #249705
All done n dusted now except for a water leak at the top of the crack where I attempted to weld it. Will go back n check it out. Water tank has an elbow inside at the bottom as I made a short @rse transporter n needed the pick up down low. Well that idea works well as in 5 minutes of running warm water started rising up n out the top hose as designed. Engine is running at 780 RPM at the moment which is just above minimum of 750 RPM. All the soldered joints are good just dont look it. I hand threw the lip on the base n dressed it to shape as I went around the tank soldering short sections. Pretty haooy with the outcone now to sort out the leak.
1 year 6 months ago #249706
1 year 6 months ago #249711
People used to chuck pepper in for leaks once
Serious leaks needed a egg cracked in the radiator
Been low pressure I'm thinking it will probably seal up on it's own in time
Time to create page: 0.404 seconds
