unstick a seized /RollsRoyce Eagle 265 diesel
9 years 3 months ago #153764
by DominicC
unstick a seized /RollsRoyce Eagle 265 diesel was created by DominicC
Engine hasn't run in years . Had been refurbished shortly before coming off the road possibly still tight after rebuild, > .
This engine is fitted in an early 80's irish built DENNISON tractor unit.
9 years 3 months ago #153765
Replied by on topic Re: unstick a seized /RollsRoyce Eagle 265 diesel
I had trouble with a stuck motor and found that who had put it together had not wash off the wax on the crank and so the crank and the piston shells had welded themselves together .
After a good clean all was good . Dave
9 years 3 months ago #153766
by dieseldog
Replied by dieseldog on topic Re: unstick a seized /RollsRoyce Eagle 265 diesel
Hey mate, first make sure that rain water has not made its way into the engine, either via the exhaust or the intake. Now pull the injectors out, and blow out the cylinders with compressed air. Fill the cylinders with oil, or if you have deep pockets, liquid WD-40, and let it sit for a few days. The next step is to change the oil in the sump and fit a tee piece to the oil pressure sender fitting. Using a small thumb pump, prime the oil system by pumping oil into the fitting until you have pressure on the gauge. The most important part here is to ensure everything is spotlessly clean.
Put the oil pressure sender back the way it was and attempt to turn the engine. You can do this by either putting a socket and breaker bar on the crank pulley and use one arm only to try and turn the engine. An easier way is to "flick" the key switch to start several times and try to shock the engine free. If it doesn't free up easily, you are better off to pull the head off and have a look, rather than damage something made of unobtainium.
Once you get it turning over, wind it for a good 10 or 20 seconds to blow the excess oil out. Now put the injectors back in but before hooking the fuel pipes up, wind the engine over to get fuel coming out of the pipes and pull out the stopper. Make sure the fuel stops flowing because if it doesn't, the engine may run away on start up. If that's all good, hook the pipes up and start the engine. Let it idle at about 1000rpm for a few minutes to get oil everywhere and that's it....
Don't forget to check the coolant and any hydraulics, gearboxes, etc that run off the engine.
9 years 3 months ago #153767
Replied by mammoth on topic Re: unstick a seized /RollsRoyce Eagle 265 diesel
Given the make I presume you are in the UK?
As the heading says the motor is seized DD's advice will be stage 2. The temptation is of course to get a tow and attempt a clutch start but at this stage you have no idea what is stuck, and a cautious approach would involve dismantling to some extent. You could go from the bottom end, undoing the bigends to ensure the crank is free and to identify the offending piston(s). You will also need to ensure that the valve train is free.
Good Luck.
Good Luck.
9 years 3 months ago #153768
by Backyard Fixer
Replied by Backyard Fixer on topic Re: unstick a seized /RollsRoyce Eagle 265 diesel
Could the clutch be stuck?
Time to create page: 0.416 seconds
