at4 crew cab help
12 years 2 months ago #75893
by tonym
If you can't afford a Dodge
Replied by tonym on topic Re: at4 crew cab help
I have a single cab AT4 truck, but the Inter C1600 ex army dual cab (AWD) I bought had the door opening.
Lets see if we can't figure it out for you... Firstly and most importantly...
Are there hinges on the door? Yes,, remove the door card and look for a latch....it should be a push lever to operate the latch...as you push the door release button it pushes a flat plate...
if it has a lock there is a small triangular cam on the latch that turns... If all else fails...
Try measuring down from the window sill about 100mm and in about 50mm if there is a door lock/catch you might be able to drill a hole in the door and manipulate the latch/ lock..
Let us know how you go. If you need a photo of the latch or you need a replacement latch...
tonym1971@live.com.au
12 years 2 months ago #75894
by cam081
Replied by cam081 on topic Re: at4 crew cab help
hi tony just to through a major curve ball at you there is no hingers and no latch at all. when i look inside the door there are 2 screws about 6" up from the bottom of the door and thats about all i can see. thanks cam
12 years 2 months ago #75895
Replied by on topic Re: at4 crew cab help
HUM
No hinges & no catch means no door.
Looks like it was never meant to be opened.
Trevor
Trevor
12 years 2 months ago #75896
by cam081
hi trevor i have been looking at it and it has to open some how cuse there is a rubber looking door seal and when i wind the windo down i can flex the top half of the door. looking inside the door it has the places for the hingers and the latch there is just nothing in there. thanks cam
12 years 2 months ago #75897
by tonym
Man that's weird, sounds like someone modified it for some silly reason...
Take the two screws out and see if you can get the door off. I have hinges and latch you can have for free ( you pay only postage).
If it looks like a door and has mounts for hinges and latch we will make it a bloody door again! Hopefully its not rusty underneath the door sill, door..
12 years 2 months ago #75898
by slantie
Replied by slantie on topic Re: at4 crew cab help
cam081 - can you post some pictures of the truck?
12 years 2 months ago #75899
by cam081
hi guys it is a ex pmg truck and i was told pmg had the trucks changed so the back rite door dosent open to stop people get out on that side and getting hit by passing trafic. [img][/img]
12 years 2 months ago #75900
by cam081
sorry guys just trying to work out how to post pics?
12 years 2 months ago #75901
by allan
Replied by allan on topic Re: at4 crew cab help
Was there not a thread in a similar vein to this just recently?
www.hcvc.com.au/forum/YaBB.pl?num=1327357007
Or am I missing something?
12 years 2 months ago #75902
by cam081
hi allan yes there was a thread on it but no one ever said how to get it open and change it back into a door. thanks cam
Time to create page: 0.458 seconds
