HELP needed please! Pulling Bedford TA2 brake hub
11 years 8 months ago #92832
by kenny-mopar
Replied by kenny-mopar on topic Re: HELP needed please! Pulling Bedford TA2 brake hub
mate using the 4wd to pull the rim off mite be the go .. i had the same problem we used a sledgehammer oxy you name it ..in the end i had to put the truck down a bit with the wheels back on (to prevent the truck being slid off the jack) and i used a forklift to pull the hubs off ..even then it took a bit of effort ..once the drum is pulled about a inch or so forward then the rest is easy as its all loose by that stage
11 years 8 months ago #92833
by John Whale
Replied by John Whale on topic Re: HELP needed please! Pulling Bedford TA2 brake hub
gday boys had the same trouble with the kingpins in a mates mitsubishi no matter what we did could not move them i asked him had they ever seen grease? he then went inside and googled grease in the end out of desperation we tried a air chisel sure enough they moved 2 or 3 mill then with an f b h out they come regards whale
Time to create page: 0.380 seconds
