- Thank you received: 623
Help! Perkins died and won't restart
so you adding more tension to the spring may have cause the arm to strip the shaft or the linkage to drop off, leaving you with zero fuel flow.
I hope thats all it is, 'cause thats an easy fix.
With an electic fuel pump I would have expected you could check the fuel return line, if there is fuel coming back then your filters are still serviceable... BIDSTBC....
Keep us posted, cant have blokes having Perkins problems on here, only encourages them Oil Leakers...
/me
- wedgetail84
- Thank you received: 49
yeah that's a good point. But all the spring does is pull the linkage back onto the stop, so I can't see how the tighter spring could pull it back even further. Also, it did have the high idle thing - which I gather from mrsmackpaul's post can be caused by a blocked filter. But yes some fuel was returning to the tank, and some was reaching the injectors like I said. Could some be getting through but not enough?Wedge, having read what you said, it seems to me the problem stems from when you adjusted the spring tension. So I would start there, if I remember right the linkage and spring hook into a little arm that sits on a spline in the pump, I recall the arm is adjustable....
/me
- wedgetail84
I open some bleed screws to check for air - none at the filter but the two little ones at the pump, sure enough there's a heap of air in there. I put another 20L of fuel in, bled it and all is good for about a minute or two then back to the same hunting. Doesn't matter whether the tank cap was on or off. So I pulled the lines going between the IP and filter, inspected, reinstalled and bled. Same again - good for a while but quickly degrades.
So obviously air is getting to the IP after the filter. The lines look ok, but they're plastic ones and I can't tell if the olives have been over tightened or something. Are there any gaskets that could go in the IP and let air in? Have others ever had this problem? Am I on the right track? Im thinking I should get some new copper line, olives and replace those two lines... Anything else I should try first?
Does it have white smoke for a few seconds when you get it first started after all the bleeding - a good indication of air in the lines.
Those plastic lines can crack just like copper lines if they are kinked and of course they can rub through.
After checking all the lines and every connection particularly where it goes into the pump and filters and finding they are OK you might look at the pick-up line into the tank. They can vibrate and crack. A really frustrating problem is a pickup cracked halfway up the pipe in the tank. Full fuel - runs like a dream but as the level drops it uncovers the crack and sucks air.
A good check is to run a length of line from the pick-up pump (is the bowl really well seated?) along the side of the truck and straight into the tank filler to bypass the complete system to prove or disprove the lines and filters are the problem.
I mentioned it in another thread recently. Spend 10 minutes on taking out the bleed screw from the injector pump. Cut a 4 inch nail to about 1 1/2 inches long then silver solder or braze this (suppose if you had a steady hand you could MIG it) to the head of the screw to form a "T" handle. It will save you a huge amount of time with no dropped spanners or burned hands whenever you need to bleed the engine.
- wedgetail84
Sorry lang you got the wrong end - the air is in the line after the filter - way after the lift pump. It's air free from the tank to the filter, the air is in the injector pump and nowhere else. So I managed to find some 5/16 copper pipe and have replaced the lines to and from the filter to IP. Absolutely no change, runs fine then in a couple of minutes has air.As the air is in the line at the lift pump it looks like - at this stage at least - you can discard anything to do with the engine, injector pump, engine fuel filter seating etc.
Now I'm not sure what to look at... Any obvious pump gaskets? Or is it more serious? Funny the way it wasn't doing this at all a couple of days ago.
Like the T handle idea I'll upgrade my nipples
gravity feed the pumper
process of elimination
May B
- wedgetail84
So anyone know of a working CAV pump going spare? Or is there a gasket/diaphragm I can replace?
