Fuel cost help
New user and first time owner of prime mover. I recently bought Mercedes actros 2646 to do Melbourne to Sydney. Just after my first 2 runs I had to put the job on hold as the fuel consumption blew me away. Can someone tell me how much fuel consumption is acceptable in following route
Truck: 2008 Mercedes benz 2646 (460 horsepower) euro 3
Trailer: 3 axle tautliner on airbags
Trip: Melbourne (dandenog) to Sydney (930km)
Driving: almost all but 50km on freeway
Load: 22.5 tonne (to Sydney)
Return load: (empty)
I have parked the truck up after just 2 drops as there is nothing left for me and it is cheaper to make payments then to drive the bloody thing.
Peter
i think $1300 is way too much considering return is empty. is there something wrong with my truck? i went to mercedes they won't acknowledge it is thirsty.
Couldn't tell you what to expect out of that truck. But agree reducing top speed could decrease fuel consumption as wind drag is a big problem. (have a look at www.google.com.au/url?sa=t&rct=j&q=&esrc...vm=bv.50165853,d.aGc ) And being payed to go both ways would help also!
But just to help out might crunch the numbers for you.
$1300 of fuel at 1.54 liter comes out at around 844 Liters of fuel.
You indicate you did 930km from Dandenong to Sydney. So assume your fuel was for the return trip so total distance was 1860 km's.
So your fuel consumption was 2.2 km/liter or 45 L/100km (from my workings out anyway!).
I don't know what your type of truck should get. But I thought the figures might help.
green.autoblog.com/2008/06/03/mercedes-b...ciency-world-record/
Snaws
1952 Austin Loadstar&&&&Outside of a dog
Their is a lot of difference between driving for efficiency and normal driving. You will notice that to get that efficiency record they only drove at 50mph and was on a test track (probably flat!).
As mentioned previously driving at 90km/hr would conserve quite a bit of fuel.
Have a read of this document cumminsengines.com/uploads/docs/cummins_...ter_fuel_economy.pdf it has some interesting stuff about speed/HP and drag issues.
One interesting statement in the document is:-
Rock-Solid Rules
[ch61607] Every 2% reduction in aerodynamic drag results in approximately 1% improvement
in fuel economy.
[ch61607] Above 55 mph, each 1 mph increase in vehicle speed decreases fuel economy by
0.1 mpg.
[ch61607] Worn tires provide better fuel economy than new tires, up to 7% better fuel economy.
[ch61607] Used lug drive tires can get up to 0.4 mpg better than new lug tires.
[ch61607] Ribbed tires on the drive axles provide 2
My old C160 Inter returned approx. 10 mpg on Haulin the Hume with the trailer attached.
Gotta feed them ponies if you want them to work,
Gilly
