Mack Air Start - Question?
10 years 3 months ago #137232
Replied by Swishy on topic Re: Mack Air Start - Question?
May B the big air hose ..... she leakz
loose fitting etc
loose fitting etc
- Thank you received: 4832
10 years 3 months ago #137233
Ive had this before (split and badly perrished hose)with same result as described but any time I suggest anything Im told Im wrong so I will just shut my trap and see what happens I some times think Mrs mrsmack is on here Im wrong so often
Replied by Mrsmackpaul on topic Re: Mack Air Start - Question?
loose fitting etc
10 years 3 months ago #137234
But we stihl luvz yar Mrs
10 years 3 months ago #137235
by Ronny G
Replied by Ronny G on topic Re: Mack Air Start - Question?
I would have a good look at the little exhaust muffler,mine blew the end out of it and lost the gauze stuff from inside some time ago. I have been meaning to do something about it but know if anyone standing near there pays to warn them before you start here.
10 years 3 months ago #137236
by Kav
Replied by Kav on topic Re: Mack Air Start - Question?
Hi, You may have some broken or just stuck vanes in the starter. The barrel that the vanes run around in can wear thin and pieces will break out and this will let a lot of air escape. If your muffler is missing you can get a polythene footvalve and turn it around the opposite way to keep the dirt and stones out of the starter- this is the cheapest way.-Kav
10 years 3 months ago - 10 years 3 months ago #137237
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Re: Mack Air Start - Question?
Mrsmack,
The phrase you might be looking for is
"You're not often right, but this time your wrong"
Oh Lord, it's hard to be humble. . .
-b
-b
Last edit: 10 years 3 months ago by Bobsboy.
10 years 3 months ago #137238
Replied by prodrive on topic Re: Mack Air Start - Question?
ha ha bobsboy! yeah i thought i was wrong once, but as it turns out, i was mistaken..
Thanks for all your help and suggestions, fellas. This forum never ceases to amaze me, with the wealth of knowledge, and good ideas ( ) that are out there!
I reckon you blokes might be on to it- thats what it SOUNDS like to me- like it's working perfectly, but lost it's baffle somehow. The bit below it seems to be all complete, (thats the bit with slits in it) and I can't see or feel anywhere that's "missing" a plate or anything. So I guess I'll pull it off and check out the inside, in case there is something that I'm not seeing.
RonnyG, that sounds spot on- I stood beside it whilst someone hit the starter to see if I could see anything unusual, - I THINK my hearing may recover, perhaps by next month...
So there's air gutsing out there somewhere..Reckon I'd notice if the big hose was split though?
Hey Kav, what do you mean, a Polythene footvalve?
Thanks again you blokes, keep up the good ideas will you?
Cheers!
Richard
Cheers!
Richard
10 years 3 months ago #137239
by Kav
Hi prodrive - I used the spring loaded poly footvalves that normally go on the bottom of the suction pipe on a pump or windmill. You can get the exact size to fit the thread on the starter exhaust and I always put them in with the white thread goo. You unscrew the two ends and swap them around so that the big blast of air goes out when you are starting and the spring then comes back and seals them off to keep the water, dirt and stones out. I fitted the first one of these in 1979 and have been using them ever since and they are cheap. I was having trouble with the dirt getting into the starters when I was doing a lot of gravel road work and sometimes the fibre vanes would jam inwards.- Kav.
10 years 3 months ago #137240
Gday Guys, Thanks for all your help and suggestions! (Kav, thats a ripper- I'll remember that)
Pulled the starter off, bung / welch plug had fallen out, and of course it wasn't visible until said starter was off.
Fixed him now! Also found that the starter drive that engages the ring gear was pretty ordinary... But that will have to wait till next time!
Anyone got any suggestions on where to get bits for these? or changeover unit?
Cheers and thanks everyone for your input!
Richard
Richard
10 years 3 months ago - 10 years 3 months ago #137241
Replied by on topic Re: Mack Air Start - Question?
Mack trucks have always had the bits
Last couple of bendix drives I bought were $ 600.00 'ea
Gleemans may be ?...
edit
I just gave away a fully reco one for a couple hundred bucks last year.
I still have some stuff on the shelf but I been getting rid of all the R model stuff..
edit
