isuzu engine into 1850d
7 years 7 months ago #193017
by Ely
isuzu engine into 1850d was created by Ely
can anyone tell me if a 6BG1 motor will fit a inter 5 speed in an 1850D...was fitted with a perkins 6354
7 years 7 months ago #193018
Replied by JOHN.K. on topic isuzu engine into 1850d
The truck has a #3 SAE housing,so if the mtor has a #3SAE housing,that will fit........the clutch used is a Fuller Mini Anglespring,but its not all that difficult to match clutch plates to splines.It will probably be longer than the Perk,so mounts will need to be made up........However ,older Isuzu parts are no longer available,and I think using a Perkins Phaser would be a far more sensible option.
The following user(s) said Thank You: Ely
Time to create page: 0.293 seconds
