Let’s see some rides and loads
7 years 3 weeks ago - 7 years 2 weeks ago #197831 by Swishy
Last edit: 7 years 2 weeks ago by IHScout.
7 years 3 weeks ago #197832 by Swishy
Take 2
The following user(s) said Thank You: IHScout, PaulFH, Southbound, xspanrman
7 years 3 weeks ago #197833 by JOHN.K.
Coles S 1610 diesel electric........
7 years 2 weeks ago #197943 by asw120
Same as yours, John?
7 years 2 weeks ago #197944 by JOHN.K.
bigger than mine........but its British made,so about the same age 1957 or so so.The later ones had sheet metal made at Revesby,and rusted worse than a HQ Holden.
7 years 2 weeks ago #197947 by Swishy
The owner sed he has never seen any other pic of his coles
as most had the xtra axle
The Victorian Raulways had a few Coles as Yard Cranes
The following user(s) said Thank You: PaulFH, roKWiz
7 years 2 weeks ago #197949 by JOHN.K.
The last one pic d is a "hydramobile".......not electric.............Ive seen lots of the SP Coles ,never seen a 6 wheeler.Mine is a 4wd,not common inSPs ,but the army had a lot of 6x6 truck mounted Coles .........Once very common,mine is ex Sydney water board,and specced with a P6 for road use...........I remember CDW at Eagle Farm had half a dozen with the Ford Mercury motors.....the common motor in them.............the one on the float would be a 4cyl Ford diesel 2712E?.....................mine was a very handy machine,when I could climb like a monkey.............like all Pommy stuff,you needed an offsider.
7 years 2 weeks ago - 7 years 2 weeks ago #197950 by Dave_64
John.K. You seem to be pretty well up on these old cranes, recall the Oz Army also had a few Coles cranes mounted on 6X6 AEC p/m, didn’t have much to do with them myself, but remember they had some sort of electric drive on them where you could move the actual crane itself from the crane operators cabin, can’t recall if you could steer them that way also, but were movable backwards and forwards. I do recall an open day at the Engineers where they had an open dingy slung from the hook just above ground level and took kids on a very slow merry-go-round rides, something that would never be allowed today.
Last edit: 7 years 2 weeks ago by Dave_64.
7 years 2 weeks ago #197952 by JOHN.K.
Dave,the army ones were actually on a Coles chassis,with AEC running gear.............I believe any truck mounted Coles,even the 30/10 28 tonners could be optioned so the truck could be moved from the crane cab.......A lot of the army cranes were broken up for the trucks straight after they were sold...........Im not sure about the army ones,but the Coles manual shows an electric steering setup mounted under the truck steering wheel......All the Coles truck chassis had a transfer case,and could have a generator driven from the case.............Some of the later series electrics didnt have a motor in the crane,and used the truck motor driving a generator in the chassis.
7 years 2 weeks ago #197953 by JOHN.K.
I realize this is a bit confusing,which it is,but the truck cranes able to be driven from the crane cab had a electric motor coupled to the transfer case.,and were powered by the crane generator..................One of the army ones I looked at at the auction also had a mass of batteries in the crane.................made me wonder if the crane could be operated on batteries alone......but I dont know............and the army ones also had either a generator or motor coupled to the transfer case................in the 1950s ,a Coles 40 hp electric motor(BTH,or English Electric) cost more than a average house.
Time to create page: 0.382 seconds
