- Thank you received: 66
I.D on 4 pot Holley carb
- Rattail 1927
4 years 2 months ago - 4 years 2 months ago #206289
by Rattail 1927
I.D on 4 pot Holley carb was created by Rattail 1927
Last edit: 4 years 2 months ago by Rattail 1927.
4 years 2 months ago #206296
by Ozfury
Replied by Ozfury on topic I.D on 4 pot Holley carb
Wow....that is shiny! I've never had a new one always bought 2nd hand worn out ones.
- Rattail 1927
4 years 2 months ago - 4 years 2 months ago #206297
by Rattail 1927
Replied by Rattail 1927 on topic I.D on 4 pot Holley carb
It is isn’t it , fear not won’t stay like it .... lol apart from being shiny I cannot spend hours on a carby and the moment you put it in gear it almost dies and the worn out throttle shaft leans out on you after , I couldn’t be bothered, I’ve spent well over my budget but it’s been wet tested and set up ready to go ( I hope) ......
Last edit: 4 years 2 months ago by Rattail 1927. Reason: Information
- Thank you received: 599
4 years 2 months ago #206301
Replied by 180wannabe on topic I.D on 4 pot Holley carb
The 345 engine should have a 2 barrel Holley 2300G.
The four barrel Holley 4150G are usually only used on the 392 engine.
Your carby doesn't appear to have a governor fitted, so i am not sure.
Maybe it is from an automotive application, rather than a truck range. Without a governor, be careful not to over rev your engine.
- Rattail 1927
4 years 2 months ago - 4 years 2 months ago #206304
by Rattail 1927
[strike][/strike]Yes you are correct. It doesn’t have a governor, The 2210 two barrel which had a governor was completely knackered , I tried to separate them but couldn’t, the distributor also is electronic from the factory, i have a work shop service manual which shows a different set up i don’t know if my engine has higher compression,but it looks like a 345A , I didn’t even know about it was made let alone have one , i think it is simply because the 2210 is only on the 345A and pointless ignition , the slop in the throttle shaft you couldn’t take off unless you revved it up to take off and then it still almost stalled, the plastic cam was wrong also, I bought the 600 and an adapter , 2 barrel to 4 barrel, and no it isn’t staying like that, I’m buying a edelbrock intake manifold from the USA so that’s why I bought a 4 barrel, you can get a cam , various other things that we could only dream of, check out binder planet if you don’t already have it, Jim
4 years 2 months ago #206309
by Zuffen
Replied by Zuffen on topic I.D on 4 pot Holley carb
If you're worried about no governor you can get electronic switches that will sense the RPM and open a circuit at a preset RPM.
You can set it to whatever you want and have it kill the ignition before the revs kill the engine.
Pretty sure you would find them on eBay for very little money.
The following user(s) said Thank You: 180wannabe, Rattail 1927
- Rattail 1927
4 years 2 months ago #206319
by Rattail 1927
- Rattail 1927
4 years 2 months ago - 4 years 2 months ago #206351
by Rattail 1927
There wasn’t much to choose from, all the other ones were more like for stationary engines but thanks for your input unfortunately I spent all my money on the carby but it has a 85 mm tacho in the dash .Zuffen wrote: If you're worried about no governor you can get electronic switches that will sense the RPM and open a circuit at a preset RPM.
- Thank you received: 546
4 years 2 months ago #206367
Replied by Blackduck59 on topic I.D on 4 pot Holley carb
Money
Swiftly
Disappears
Swiftly
Disappears
Time to create page: 0.564 seconds
