- Thank you received: 1113
Air brake parts identification questions.
1 year 3 months ago #242942
Air brake parts identification questions. was created by asw120
Hi guys, there are some issues with the brakes on my dad's bus.
It's a 1978 IBC Mk3 with a 3208 and auto in the back.
Ever since he's had it, the park brakes take ages to release. Is that likely to be the relay valve? (the only ones I can identify, since they're so obvious).
Lately (it mostly sits around) the service brakes are sticking on and you have to jab the pedal to release them. Any ideas where we should look for that?
Also, could anyone tell me what these pictured things are, please? Just guessing to do with which air tank fills first. It has front and rear wet and dry tanks.
Many thanks, Jarrod.
1 year 3 months ago #242943
Replied by hayseed on topic Air brake parts identification questions.
The top 2 Pics are of a Relay Valve. Pic 3 is a quick release valve, & the bottom 2 are of the Spring Brake control Valve.
1 year 3 months ago #242944
Replied by asw120 on topic Air brake parts identification questions.
Hayseed, excellent, thank you. I actually meant quick release valve was the only one I knew, had my terminology wrong.
I have to find a plumbing diagram for this thing. We tried to follow the hoses, but they just go into a sort of loom (too many).
At least I have something to go off, now.
After this, I have to chase a big leak on the White.....(exhausting heavily out the foot valve all the time - advised it may actually be a chamber)
Thanks again, Jarrod.
1 year 3 months ago - 1 year 3 months ago #242945
Replied by JOHN.K. on topic Air brake parts identification questions.
Your White will likely need a new kit in the foot valve............one clue for slow maxi blowoff,is to wait until full pressure is up,then push in the valve ......the extra pressure will seal the various valves and stop leaks that happen at low pressure..........the blowoff tank may be too small.........back in the day,you had to be able to release the maxis fully three times with the engine stopped.............might have a leaking diaphragm ,too.
Last edit: 1 year 3 months ago by JOHN.K..
- Thank you received: 839
1 year 3 months ago - 1 year 3 months ago #242946
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Air brake parts identification questions.
Many moons ago i remember with the westinghouse system , if the diaphram got all saggy in the quick release valve,
it would cover up the exhaust port, making the release very slow...........
A new release valve should fix the situation......
As a quick fix we would pull the quick release valve apart and flip over the diaphram...........
Whether that works with yours i would not know.............
...................Billy..................
Last edit: 1 year 3 months ago by BillyP.
1 year 3 months ago #242948
Replied by Swishy on topic Air brake parts identification questions.
Lift the brake pedal up to expose the rubber boot and plunger and sparay sum WD40 to free up the pedal
they all may need a disassmble & clean and any rubber or 'O' rings re install with rubber grease or mums good petroleum jelly
https://cdn11.bigcommerce.com/s-josrcotf/images/stencil/608x608/products/5708/14983/SI932I__05636.1632834748.jpg?c=2
normally a brake shop will not stuff around ........ they fit new valves etc .......for safty reasons .......and the kits for the valves are dearer thsan a new valve
1 year 3 months ago #242949
by wee-allis
Replied by wee-allis on topic Air brake parts identification questions.
Jarrod, Forget the brake problem. What's with the 3 legs. I see 2 with shoes and socks and one with thongs. Maybe the one is holding the peddle down when you arn't looking.
1 year 3 months ago - 1 year 3 months ago #242950
Replied by Lang on topic Air brake parts identification questions.
Jarrod
I replaced both those identical valves on the Renault/Mack. They were leaking and sticking and internally corroded with oily/watery porridge. Action Mechanical used to be called Action Brakes in Northgate Brisbane ordered them in for me and I was very surprised how cheap they were. Took about an hour to chase all the various pipes (mark each and the corresponding valve port as you take them off!!!!) but it was like a new truck afterwards.
Air Brakes in Rocklea will actually rebuild stuff.
As the other blokes who know more than me mentioned could be in the foot valve
Last edit: 1 year 3 months ago by Lang.
1 year 3 months ago #242959
Jarrod, does it it only do it with the park Brake off..? or all the time.?
1 year 3 months ago #242960
Replied by mammoth on topic Air brake parts identification questions.
Treadle valve is a pretty frequent culprit and not many mechanics who have yet to retire have ever fitted a kit. A new E6 treadle valve will be around or less that $100. A trade secret from a towie is to squirt your favourite oily stuff down the compressor air intake, instant fix for exhausting treadle valve and other ills.
Time to create page: 0.548 seconds
