- Thank you received: 7702
Hydro boost brakes
- Mrsmackpaul
1 year 8 months ago #251199
Hydro boost brakes was created by Mrsmackpaul
A simple question, or maybe more than a simple question
are hydro boost brakes legal in light trucks etc in Australia ?
with vacuum brakes, you need to gave a vacuum reserve tank that allows a certain amount of brake applications (think maybe 4, maybe more) before the vacuum is depleted that the braking efficiency is affected
Air brakes on trucks are the same, must have a certain volume of reserve air
I guess this rule doesn't apply to cars as the moment the cars not running you have lost vacuum and the have no vacuum tank like a truck
so getting back to hydroboost, these run off the power steering and have a accumulator, Yanks seem to love their hydroboost and fit it to every thing as after market fix all
are these legal in Australia for trucks, I would imagine cars have them already
well I did some googling and found this on light vehicles, no mention of hydrboost yet
however it does mention that 2 full applications of the brake without the motor running is required
It doesn't even mention hydroboost brakes that I can see
1 year 8 months ago #251200
Replied by Swishy on topic Hydro boost brakes
Mrs
gudday m8
Hydo Boost could B a trade name may B they be called Vacuum assisted brakes
our ol Holden has 'Power Brakes' inscribd on the brake pedal
can remember trucks havein rear signs
'Caution Air Brakes'
gudday m8
1 year 8 months ago #251201
Replied by Lang on topic Hydro boost brakes
I think Swishy is right.
With air or pure vacuum once you lose the system you have zero brakes therefore the required engine-off reserve and the introduction of maxi-brakes.
With the "boost" type system all it does is make the pedal pressure less so lost boost just means heavy pedal pressure but still braking (like lost power steering failure). Suppose similar to air/vacuum over hydraulic in some applications but I think some of these lose even the unassisted operation as well.
Maybe an expert can explain more precisely?
1 year 8 months ago #251203
by PaulFH
Replied by PaulFH on topic Hydro boost brakes
Landcruiser and diesel utes most have electric hydraulic boosted system. Hear the pump run as key is on. Not sure how they work.
- Mrsmackpaul
1 year 8 months ago #251204
Replied by Mrsmackpaul on topic Hydro boost brakes
I think the rules are very different once it becomes a commercial vehicle rather than a ute
Hydroboost requires the engine tp be running, were as full air or vacuum are fail safe
I guess a hybrid version is air over hydraulic and or vacuum over hydraulic
The braking efficiency is greatly reduced if these power assisted brake boosters aren't there
Hence the need for a resivor and a non return valve
All I guess Im wondering is would hydroboost be legal and if so is there anything in the commercial vehicle type of thing on the market with hydroboost in Australia ?
- Mrsmackpaul
1 year 8 months ago #251205
I guess I'm seeing if we have amy experts on here to advise on this
Maybe in the back ground that have gone down this road
1 year 8 months ago #251206
by V8Ian
Replied by V8Ian on topic Hydro boost brakes
Most 4x4, utes etc have a vacuum pump integrated on the back of the alternator.
- Mrsmackpaul
1 year 8 months ago #251207
Yes they do, they seam simple and reliable
Small American diesels have a vacuum
Trying to think what Perkins use, a device that creates the vacuum and it has a proper name but the brain isnt smart enough today
Americans seem to have taken a real dislike to vacuum boosted brakes for some reason that I can't figure, mainly on their bigger/ full size pickup type utes
I'm not sure if I'm the dumb one and missing the obvious because power boosters seam reliable to me
1 year 8 months ago #251214
by wee-allis
Replied by wee-allis on topic Hydro boost brakes
From watching a few Yanky hot rod and resto shows, as Paul said, they seem to love the Hyroboost system as a replacement for the vacuum boosters normally fitted to older cars. It fits up just as the vacuum one does, ie between the pedal and the master cylinder.
Haven't see where the hyd. pressure pump is fitted, maybe as Paul said, the power steering unit.
1 year 8 months ago - 1 year 8 months ago #251215
My OKA has Hydroboost system. One thing they are noted for is outstanding brakes.
The Oka has a 4 wheel disc brake hydroboost braking system as standard with front and rear disc/calipers the same. Not bad for an early 90's vehicle and with the hydraulic pump cam/gear driven brakes and power steering are independent of the fan belt. A very efficient and reliable way of doing things.
This is the OKA system except the OKA pump is gear driven so if you lose your fan belt you do not lose your brake and steering assist.
Last edit: 1 year 8 months ago by Lang.
Time to create page: 0.343 seconds
