- Thank you received: 42
old truck and ancient load
13 years 10 months ago #30524
old truck and ancient load was created by
13 years 10 months ago #30525
by atkipete
Replied by atkipete on topic Re: old truck and ancient load
Great photo Roland, we got a truck out here called the "International Turbostar" which used that Iveco cab in the early 90s
13 years 10 months ago #30526
Replied by on topic Re: old truck and ancient load
G'day Pete
Yes the IVECO cab was used by several manufacturers, including the Russian Uralaz I recently went on about.
If I can get more info on the old AEC I will put it up here.
Cheers mate
RS
Cheers mate
RS
13 years 10 months ago #30527
by atkipete
13 years 10 months ago #30528
by kennymopar2
Replied by kennymopar2 on topic Re: old truck and ancient load
the iveco 'eurocargo" cab ..was a continuation & update of the ford cargo cab ?
13 years 10 months ago #30529
Hi Kenny
You are right.
When IVECO bought up Fords European truck operation in 1986 , they started to use the Eurocargo cab.
The Original Cargo cab which was built in UK and Germany ( possibly Belgium also ?) was dropped.
The Eurocargo cab became a general mid range cab, and is the basis of the ACCO cab as used in Dandenong.
There is now a MK2 Eurocargo cab introduced in 2003, with a wedge shaped grille configuration which brings it in line with the larger Stralis cab. The Stralis cab is built at the former Magirus Deutz factory in Ulm Germany.
IVECO is a truly international company.
I am surprised that the 'Transit' van has continued in its monocoque construction, and that it has not been introduced with the superior, chassis/bodywork 'Daily' format, i.e a small truck, rather than a large car.
Maybe this will happen soon.
RS
You are right.
RS
13 years 10 months ago - 13 years 10 months ago #30530
by werkhorse
Replied by werkhorse on topic Re: old truck and ancient load
Aww heck.....now the nightmares will begin ..again....
had many a disasterous trip in this POS
You never knew which way it would steer...it was totally under powered...the gear change was almost impossible to change.........must I go on.........
Only good thing about it was the tray that folded out of the dash to hold you lunch while you ate.
Last edit: 13 years 10 months ago by werkhorse.
13 years 10 months ago #30531
by atkipete
Well I suppose that table would be great to eat at whilst you were broken down.
Now Roland, the ACCO cab is nothing to do with the Eurocargo cab, although recent changes to the grille have made them look similar. The current ACCO cab was designed by International Harvester in 1968 and released in 1972. Had a few changes over the years but the basics are still the same. For more info I recommend that book "The ACCO - An Aussie Icon"
13 years 10 months ago #30532
by disco
Replied by disco on topic Re: old truck and ancient load
Roland, this what Iveco does best , confuse's the f@#$ out of every one
13 years 10 months ago #30533
G'day Pete and Disco
CONFUSED... or what
It must be my age
I will have to read the ACCO book again.
RS
CONFUSED... or what
It must be my age
RS
Time to create page: 0.490 seconds
