tri axle c1600 international????
- v8 inter nut
12 years 3 months ago #73634
by v8 inter nut
tri axle c1600 international???? was created by v8 inter nut
12 years 3 months ago #73635
by elgindale
Replied by elgindale on topic Re: tri axle c1600 international????
12 years 3 months ago #73636
by Bruce99
Replied by Bruce99 on topic Re: tri axle c1600 international????
Looks a bit like the 3rd one is just chained up?
Might be a spare he's bringing home from the wreckers??
12 years 3 months ago #73637
by tonym
If you can't afford a Dodge
Replied by tonym on topic Re: tri axle c1600 international????
Geez, and to think! I only carry spare points, fuses and maybe a new spark plug just in case.
He carries a spare diff, hubs, bearings... Etc..
Might have to upgrade my glovebox.
12 years 3 months ago #73638
Replied by Lang on topic Re: tri axle c1600 international????
Wonder why we don't see more of this here. Everywhere you go in Europe you see trucks with the third (and even second axle) tucked up and only lowered when the load required it. Buses also with their pusher raised.
This Inter obviously has a simple but effective method of using the truck jack to lift the axle (or driving on to a log) and slipping the chains over hooks. The fancy way is to have hydraulic lift or use the airbags.
Saw a new Volvo tipper yesterday with a lifted axle.
12 years 3 months ago - 12 years 3 months ago #73639
Replied by on topic Re: tri axle c1600 international????
I don't see what this bloke is trying to achieve, with a tandem, and a 3rd lift axle as well, behind it, on a C1600.
A C1600 has a GVM of 16,000 lbs (7259 kgs) .. and even if the owner had it re-rated to a higher GVM .. there's still no way he could get the total loading of 25.5 tonnes on the rear axles (16.5 tonne on the bogie and 9 tonne on the lift axle) that this combination is capable of .. on a truck chassis that's originally rated at a little over 7 tonnes total??
12 years 3 months ago #73640
Replied by hayseed on topic Re: tri axle c1600 international????
I'm with you Ron.
WTF was He on
It'd be strictly highway use only!! The first gutter/kerb he came to, he'd be sitting & spinning
Besides, If he did load it up, It'd be under powered to buggery :'(
Looks like someone had tooo much time on their hands :
WTF was He on
12 years 3 months ago #73641
by jeffo
Replied by jeffo on topic Re: tri axle c1600 international????
The first lazy looks like a BPW setup, but the last one is a bit home made.
Judging by the brake drums it would only be on single tyres, probably an old front axle.
It would be interesting to hear its story.
12 years 3 months ago #73642
by ct7scott
At4 560 313&&At4 129 225&&HR
Replied by ct7scott on topic Re: tri axle c1600 international????
this reminds me of our at4 560 in the 80's. Dad hated the "rock and roll" of what was otherwise a fantastic truck, reckons he had no skin on his right elbow where it dragged in the paddock. Every morning before work (wheat carting) he would grease the accelertor pedal linkage so when it lurched he could use the counter torque of the 313 to stand it back up! Then one day he found a front axle with springs and hangers at a clearing sale, he welded up the king pins and welded the hangers directly to the chassis as his lazy axle. worked a treat for many years, until this one day when the RTA pulled him up. Aperantly they had a sense of humour failure when they crawled under the truck and found all those "cocky welds"
12 years 3 months ago #73643
Maybe he had a field bin the size of the one on the tri-axle ACCO and didn't need more than first or second gear to get around the paddock but needed something to stop the back wheels scraping under the tray when fully loaded?
