OK I Will Go First
- Rusty Engines
13 years 3 months ago - 13 years 3 months ago #43613
by Rusty Engines
OK I Will Go First was created by Rusty Engines
Last edit: 13 years 3 months ago by Rusty Engines.
- Rusty Engines
13 years 3 months ago - 12 years 11 months ago #43614
by Rusty Engines
Replied by Rusty Engines on topic Re: OK I Will Go First
Last edit: 12 years 11 months ago by Andy Wright.
13 years 3 months ago #43615
by Slimline871
&&1924 Hart-Parr Type 20&&1966 Chamberlain super 90&&1959 Twin City G-vi&
Replied by Slimline871 on topic Re: OK I Will Go First
13 years 3 months ago #43616
by HeyCharger
Proud owner of;
1948 Massey Harris 44K.
1946 Ford Semi-Trailer Bus.
Replied by HeyCharger on topic Re: OK I Will Go First
Was that last piccy a whoooops! or a "but I thought you....." :-[
Proud owner of;
13 years 3 months ago #43617
by melonreo
Replied by melonreo on topic Re: OK I Will Go First
i used to operate this truck for 3 years . my boss loaned it to me for a long weekend to go to plow and be counted at cootamundra (do what ever i want with it ) BUT you better look at the pic quickly as i dont rember getting his permission to take any picture , and shareing them with lots of good people , so look fast as i will surely have to remove it soon
13 years 3 months ago - 13 years 3 months ago #43618
by Slimline871
Hey Charger,
That was definatly a 'whoops" moment lol. Truck was in reverse with the handbrake slapped on but a worn 289 (??) and a handbrake that wasnt the best was no match for the thumping lanz, which then proceeded to push the truck away from the ramp when i got the rear wheels on! Knew i shoulda worn my brown pants that day!
Melon,
Which ones on the back are yours mate? Nice load of gear!
Cheers,
Slim
Melon,
Cheers,
Slim
Last edit: 13 years 3 months ago by Slimline871.
13 years 3 months ago #43619
by Tacho
Replied by Tacho on topic Re: OK I Will Go First
Hey you blokes. That is so not fair to put up pics of things I want. Unfortunately, the longer you are in this hobby the longer the bucket list gets. Great stuff.
Geoff
Geoff
13 years 3 months ago #43620
by wouldyou
Replied by wouldyou on topic Re: OK I Will Go First
Here's our Rumely, Bit of a hybrid, mostly model L 1927 with some of next model W. Oil cooled, the exhausts go through a venturi at top of radiator, the theory being the harder it's working the more cooling air getting drawn through.
With higher compression than normal [when it was new anyway] and being able to run hotter with oil coolant it vaporised the kerosene better, these factors caused pre-ignition so there is a double carby with one side supplying water from the tank in front of motor, the kero tank mounted in the chassis below is about the same size, presumably fuel and water was used in equal amounts. 25 HP, 3 speeds and diff lock. Bought new by an uncle and used 'til 1946. Apologies for pic size, have cropped it in puter album but this is as from scanner. David.
13 years 3 months ago #43621
by Slimline871
Seeing as we've now got a dedicated page to tractors, thought i might aswell be the first to throw some pics on of current resto projects, im sure there's plenty out there!
So , here's mine at the moment, a 1947 Field Marshall series 2.
Had been sitting in the weather a LONG time, hence the tree stump growing through the drawbar. I'm rebuilding the engine due to extensive water damage.
13 years 3 months ago #43622
by wouldyou
