Best aggressive coolant flush for Chev blitz
Is this definitely an original Blitz 216? Those oil pressures are unheard of normally. Chevrolet says 14 psi at 30 mph in top gear for new engine.
Idle in the manual is required to be "Indicating".
I have had a few of those engines and covered some very long distances really like them but never seen 20 psi for more than a short time after a cold start. A Chev ute I took to Europe did 6,000 km trouble free at 5-7 psi dropping back to zero if I let the revs drop right back on hills. You must have a good'n.
Someone hasn't dropped a 235 in??? Early ones are hard to tell the difference just looking at them.
Bore and Stroke: 3-1/2 x 3-3/4
Piston displacement, Cubic Inches: 216.5
Compression ratio: 6.60
Maximum Brake Horsepower: 92 @ 3400 RPM
Maximum Torque Lbs.Ft. @ RPM: 174 @ 1200
Normal Oil Pressure Pounds: 14
The lean mixture has a longer burn time, result is a hotter engine and burnt exhaust valves can happen.
- wedgetail84
- Thank you received: 49
Haven't had the plugs out for a while too - but do you think lean running fits the description I gave?morrisguy wrote: Somebody may have mentioned this already. Have a look at the spark plugs and check for lean running ( light coloured insulator ) . If the fuel air ratio is wrong, the engine may overheat .
Yes it's a 216 for sure - many things I remember about it indicate (can't remember bore dimensions) but at the least it has splash fed big ends... I might be a tiny bit off in my oil pressure figures when checking against the manual or others' it has very good pressure.Lang wrote: Wedgie
Here's a vid of a short road run from a while ago. Don't think I had a temp gauge at the time - I was blissfully ignorant!
This might help you en.wikipedia.org/wiki/Chevrolet_straight-6_engine
This is misleading , don't believe everything you read on wiki ?
The 216 engine :
" This engine was also used in GM's British Bedford truck"
I think they mean a similar engine , not the same engine . Somebody should edit that boo boo
- wedgetail84
- Thank you received: 4757
I got given a book on Bob Chamberlain for Chrissy
And in it they talk about all the companies that Chamberlains had and one company was the Rolloy piston company and they made alloy and something else pistons that were fused together
They also mentione about Ford V8's made during the WW2 for the military and the book says that a lot of metal components that make the metal in the block were missing because the motors were made to only last 10000 miles at the most
And after the war people werent getting a good run out of these brand new motors
Im pretty sure they made chrome sleeves to push into the block to make then last a lot longer
I wonder were Chev motors of the same time made along a similar line and perhaps inside the block is falling apart or maybe a lot of the block has corroded very thin and its now like a porous block which causes exactly what you describe
A lot of these were made from steel and rust out, so you don't get an even flow through the block and head.
Beaver@ Museum of Fire
