- Thank you received: 1569
Best aggressive coolant flush for Chev blitz
Steve.
- wedgetail84
- Thank you received: 49
As to no thermostat causing over heating, this tends to happen more with modern vehicles, (cars mainly), with their smaller radiators. It seems that the more rapid flow of water does not leave enough time to cool while in the core. This I have found to happen on several vehicles. The opposite can also happen, as I had a Toyota Hi-lux van and the heater wouldn't work in winter with out the thermostat because it was staying too cold.
My two bobs worth.
Steve.
water jacket holes line up and by extension all the holes in the head gasket?
Just an idea. I hope I haven't missed something and this theory has already been discussed. Cheers
The cast iron alloy pistons on those wartime engines can be a little fragile, don't over rev it too much, the piston tops can break off ! The cast iron alloy pistons do have advantages, the ring grooves don't wear ! They can develop loose piston pins and knock at idle . I have a crate of .040 pistons I bought years ago at Corowa, Uptons the machinery dealers had them in WW2 crates . My 216 has a loose piston pin, it knocks at idle . I have a 1940 Chev 4x2 army vehicle , it has 900-13 tyres .
Sometimes you're the windscreen, sometimes you're the bug.
- wedgetail84
Well my memory fails me over that length of time. I assume so... But it was meant to be a blitz block, and hopefully I checked all that. But I'm not pulling to head to find out either!mackme wrote: Hi mate you say that you fitted the original head to another block. Did all the head to block
I'm not that forum too - I guess I could have posted this problem there too. It's just I use this more and thought it's probably more a general engine problem of which there is plenty of experience here... It has alloy pistons - the block was rebuilt in the 50s and bored oversize with new pistons, bearings etc.. My uncle fitted it all up and used it for a while, mostly running a saw mill before I pulled it down, inspected/measure reassembled. He reckoned it never ran right (head needed love) and overheated then too.morrisguy wrote: In your video , the engine sounds nice, no nasty noises . Are you planning to fit a army body or keep the tray ? The MLU forum will be good for you , The blitz people use that forum more often than this forum .
I'm planning on putting the tray back on that it had when I got it - it was ex RFS (Hill Top southern highlands), but it's timber and needs 100% (minus hardware) rebuilding. I'm more interested in the civil life of blitzes after war than their original military trim perfectly restored examples which get more coverage. Mine will not be green and is looking like it might not be 216 powered either! All more reasons to post here rather than MLU - I feel if I mention all that on MLU I'd be cast out :dry:
Problem is pulling the tanks off the cruiser radiator is fairly time consuming. Id would be much quicker to shove another rad in (the 4th) - I have plenty of cruiser rads that have hairline cracks in the cores which I know cool a working 1HZ or 1VD-FTV no problems, just like the current one cooled a 1H motor no worries. I think I've ruled the rad out just by swapping that many in and out. Maybe the timing could be wrong, but I don't have a light. Is there a better way to check? It runs, starts well with good power and no pinging.towball wrote: like wee-allis said, take the tanks off the radiator and make sure the tubes are clean. Timing has a lot to do with overheating. Just because it run's ok doesn't mean it is right. The thermostat slows the water down so it cools as it passes through the radiator and also regulates the heat in the engine. Cold metal wears quicker than metal at operating temperature.
- Thank you received: 547
A vacuum gauge will be a better check while running.
