- Thank you received: 2501
To beavertail or not???
11 years 4 months ago #103980
Replied by hayseed on topic Re: To beavertail or not???
How strong's your headboard???
Could you rig a pulley up so as the Winch is pulling from the Top of the headboard.....
Sorry Rod, just thinking out aloud.......
11 years 4 months ago #103981
by PeterE
Peter&&Narrogin WA&&AT4 229
Replied by PeterE on topic Re: To beavertail or not???
How's this for an idea?
Mount the winch at or near the back of the tray (underside). If the cable runs to a pulley then up to top of tray , or, through a slot in the tray, then you could easily pull up vehicles from their rear end and you could get good angles to pull on the ramps. If needed you could pull cable under tray out the back for something lower and further away....
Peter
Peter
- HeyCharger
11 years 3 months ago #103982
by HeyCharger
Proud owner of;
1948 Massey Harris 44K.
1946 Ford Semi-Trailer Bus.
Replied by HeyCharger on topic Re: To beavertail or not???
ah ha... Just saw this;
The bracket half way up is to stop the bi-fold flapping around. Up the top is where it all happens. As the ramp is lowered, the chain is attached to the lever extending from the top of the shorter ramp. As the ramp is lowered, the chain pulls the lever, thereby extending the back half. Brilliant.
Proud owner of;
11 years 3 months ago #103983
Replied by on topic Re: To beavertail or not???
Heycharger
Some very clever thinking gone into that one as same chain also acts as safety for the ramps when travelling. ?? did you also have a tape measure handy to get a few measurements.
Trevor
Trevor
- HeyCharger
11 years 3 months ago #103984
by HeyCharger
Proud owner of;
Drat. No I didn't and I had a NEW 10m (imperial/metric) tape measure straight from Aldi in the car too.
The extension bar out the top would have only been 6-8". Brilliant bit of thought gone into it.
Proud owner of;
11 years 3 months ago #103985
by Bugly
Replied by Bugly on topic Re: To beavertail or not???
I like it!! [smiley=thumbsup.gif]
11 years 3 months ago #103986
Replied by Swishy on topic Re: To beavertail or not???
- HeyCharger
11 years 3 months ago #103987
by HeyCharger
Proud owner of;
Hi Swishman. So what (in your piccy) makes the shorter legs extend to the horizontal?
Proud owner of;
11 years 3 months ago #103988
Hay
Charger
when u slak off the chain u thro it over th@ 1/2 circle lug @ top of ramp th@ when u lower the ramps it fliks the bottom section out n parallel to the main part of ramp connected @ trailer
we put the ramps on the Drake float bout 7 years ago n then took m off az there B more demand for not have n m
they just pinned on n bout 20 mins to fit again
Charger
- HeyCharger
11 years 3 months ago #103989
by HeyCharger
Proud owner of;
Ah. I see it all now. Please remember that if possible, I do not want to use hydraulics to lower the ramps. I want to use a winch mounted at the front of the tray.
With the photo I posted, I could accomplish this (I think).
Proud owner of;
Time to create page: 0.559 seconds
