- Thank you received: 137
To beavertail or not???
11 years 4 months ago #103990
Replied by on topic Re: To beavertail or not???
Heycharger
Can you draw us up a mudmap with what you are thinking, coz i cant see how you are going to pull from the front as the ramps are going to be below centre when they are down.
Picture below show my little isuzu with the winch mounted in the middle at the front, since this picture was taken i have fitted the ramps as per second picture.
Once the ramps are down the cable would be trying to pull straight back on its self to try and lift them and that just will not work, if you put either the winch higher or somehow lift up the rear point you will not be able to have anything on the tray.
If i get a chance tomorrow i will lay the ramps down and pull the winch out and take some pictures.
Trevor
Trevor
11 years 4 months ago #103991
11 years 4 months ago #103992
Replied by geoffb on topic Re: To beavertail or not???
Trev
Didn't know you where a artist
11 years 4 months ago #103993
Geoff
Have been called a lot of things before but artist
Trevor
Trevor
- HeyCharger
11 years 4 months ago #103994
by HeyCharger
Proud owner of;
1948 Massey Harris 44K.
1946 Ford Semi-Trailer Bus.
Replied by HeyCharger on topic Re: To beavertail or not???
Hey Trevor. You spotted my obvious problem .
So the cable has to be attached to a point above the level of the tray to be able to pull it up.
In very simple terms, what is needed is say a vertical post (about 2' long) mounted, say 3' down from the tray hinge point.
Now the real problem is that the cable will now foul on vehicles on the tray
Apologies for creating a crayon forum
Proud owner of;
11 years 4 months ago - 11 years 4 months ago #103995
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationCome inside its playschool
Easiest solution might just be something like this
one of these
Couple of these
And a couple of short hoses.
Jobs done neat tidy and safe.
Then just have the winch for what its best at.
Added: Or what about a set of Aluminium ramps like my ones i paid about $900 for the pair.
Trevor
one of these
Couple of these
Trevor
- HeyCharger
11 years 4 months ago #103996
by HeyCharger
Proud owner of;
Sort of agree with you Trevor. But I keep in mind that the hyd setup will cost me about $grand.
That about as much as I paid for the truck
Don't want to over capitalise. .
Rod.
Rod.
Proud owner of;
11 years 4 months ago - 11 years 4 months ago #103997
Replied by Lang on topic Re: To beavertail or not???
Simplest would be balance springs like you see on the ramps of horse-float trailers.
You can either have the long spring that slides along the ramp as you lower or these smaller twisting ones.
www.mrtrailer.com/titan_trailer_flatbed.htm
Here they are at $16 each.
www.easternmarine.com/right-hand-torsion...21-23-in-lbs-3002880
Last edit: 11 years 4 months ago by Lang.
- HeyCharger
11 years 4 months ago - 11 years 4 months ago #103998
by HeyCharger
Proud owner of;
If I run the cable from the front of the tray on top of tray to the rear and then UNDER the ramps to the bottom rung of the rearmost of the ramps (which touch the ground) this may work.
Going to make a very rough wooden model of what I think I can do, to see if it works.
Lang thanks but my ramps bi-fold UNDER not over.
Rod.
Rod.
Proud owner of;
Last edit: 11 years 4 months ago by HeyCharger.
11 years 4 months ago #103999
by dodgemetal
Replied by dodgemetal on topic Re: To beavertail or not???
well not sure if this would work but it does in my mind, and only uses the one lead.
So when raising u run it under a roller at the back of tray, and under roller placed out lower on first part of ramps, and should raise up,
when lowering u run it under first roller but over second one's cross beam, should lower alright.(havent drawn that in pic though).
As it's not a widening float(what i usaully deal with) u can put the cross beams in no problem. The lower bit on for second roller would stick out when up but shouldn't get in way if measured right and having all the force applied in centre distributes the weight well. long as u ok with a welder shouldnt cost much for 2 rollers.
Time to create page: 0.574 seconds
