- Thank you received: 1996
New Model Cat Engine
5 years 8 months ago #213967
Replied by mammoth on topic New Model Cat Engine
so how come there is a 'blue fuel line' going to a coil?
- Thank you received: 582
5 years 8 months ago #213970
Replied by Blackduck59 on topic New Model Cat Engine
Coil? Thought that was the electric lift pump for the injection pump
5 years 8 months ago #213972
Replied by Lang on topic New Model Cat Engine
Further investigation reveals all the electrical connections on the bottom of the photo are part of the electronic engine control system regulating the performance. As mentioned above the round object with a fuel line to the injector pump is a lift pump. Mammoth is correct it is a "coil pump" similar to a screw pump. The name comes from situation where it fails and you are screwed.
lang
lang
The following user(s) said Thank You: Aussie Truckin
5 years 8 months ago - 5 years 8 months ago #213973
by wee-allis
Replied by wee-allis on topic New Model Cat Engine
I'm so proud to be part of this forum and share information from such knowledgeable folk. Keep it up. TIC>
Last edit: 5 years 8 months ago by wee-allis.
5 years 8 months ago #213978
Replied by asw120 on topic New Model Cat Engine
After the unprintable day / night I've had, I needed this!
- Thank you received: 844
5 years 8 months ago #213980
Replied by 180wannabe on topic New Model Cat Engine
I have a yellow 308 "known as a 3(2)08" in my WB ute. It was a mate's idea, he said "while it's out, paint it yellow and put Caterpillar stickers on it!", so i did.........
5 years 8 months ago - 5 years 8 months ago #213985
by Mairjimmy
Replied by Mairjimmy on topic New Model Cat Engine
Lang I haven't been convinced that is what you say but who am I to doubt you, its not April fool day is it :dry: :dry: I have just noticed the fuel filter bowl, looks like diesel in it :blush: :blush: :oops: :oops:
Last edit: 5 years 8 months ago by Mairjimmy. Reason: to add one ord
5 years 8 months ago #213988
by wee-allis
It's obvious that this conversion was not easy, going by the amount of extra wiring and number of relays required. Probably has a massive Cracking plant in the back to convert the water to diesel.
5 years 8 months ago #213990
Colin
Thanks for the proof of my assumptions. Blows those naysers talking about petrol out of the water.
5 years 8 months ago - 5 years 8 months ago #213992
by Mairjimmy
Lang If "wee-allis" is correct then maybe, just maybe it has another conversion plant to convert diesel to petrol:dry:
wee-allis wrote: Probably has a massive Cracking plant in the back to convert the water to diesel.
Last edit: 5 years 8 months ago by Mairjimmy. Reason: add a word
Time to create page: 0.301 seconds
