- Thank you received: 2500
Valve extensions
3 years 1 month ago #219489
Replied by hayseed on topic Valve extensions
if you're goin into sandy Country & letting your tyres down & pumping them up on a regular basis/ these might be worth considering..
powerdown.com.au/products/cats-eye/
- projectinter
- Thank you received: 19
3 years 1 month ago #219492
by projectinter
Replied by projectinter on topic Valve extensions
Thanks Hayseed. I think they are pretty expensive. Always been going to get the Air cti on the 4x4 truck which is meant to be pretty good. This hino doesn’t have air and is pretty old so I’ll just let them down by hand.
3 years 1 month ago #219493
by overnite
Replied by overnite on topic Valve extensions
ProjectInter, definitely steel. Bought mine from ebay (bits4blokes), about $7 each, or much cheaper in multiples.
3 years 1 month ago #219503
Replied by cobbadog on topic Valve extensions
Mine are the Schrader brass ones about 4" (100mm) long and do the job well. You only need a pair for the inside rears only and no where else. AS mentioned these extensions do not hold air at all only have a long needle that pushes against the valve core on your tube. I have not used the braided ones but the poossible problem there is anchoring them from flailing about as you drive and see them flex and break.
3 years 1 month ago - 3 years 1 month ago #219511
Replied by Lang on topic Valve extensions
No eBay APP ID and/or Cert ID defined in Kunena configurationThey are almost give away price. Many different shapes and lengths on Ebay for a few dollars. I vote for them instead of stuffing around trying to get the stem off the rim to put the air fitting on or even reach the damn thing in the first place.
Last edit: 3 years 1 month ago by Lang.
3 years 1 month ago #219516
by paulc20
Replied by paulc20 on topic Valve extensions
Alcoa recommend that you Do Not use metal valve extensions unless they have a support. They say to use plastic.
Check page 12 in this manual: www.alcoawheels.com/alcoawheels/australi...e_manual_english.pdf
I have plastic extensions on my 45 year old Alcoas.
3 years 1 month ago #219528
Metal ones are fine on metal rims that run 8.25x16 tyre and tube.
- projectinter
3 years 1 month ago - 3 years 1 month ago #219537
by projectinter
I bought a set of metal ones from tyre shop. $10 each.
Went to fit them but I can’t even fit my hand in to take the valve cap off. I’ll take the wheels off and put them on.
Bloke at the tyre shop reckons plastic ones are okay but reckons if you drive a lot of dirt roads they’ll get smashed by a stone.
Thanks for all the replies.
Last edit: 3 years 1 month ago by projectinter.
3 years 1 month ago #219542
From my failing memory I used a pair of long nose pliers to remove the valve caps. Then the standard valve was lying against the rim so with a long thin screw driver I was able to screw the extension on by hand then using that hex on the end of the extension where the valve cap will be fitted again I used a small shifter to tighten it up.
If you have a choice of valve caps only use metal ones as they have a seal inside to ensure no loss of air out passed them. Plastic ones are better than none.
The following user(s) said Thank You: projectinter
3 years 1 month ago - 3 years 1 month ago #219544
Here is a shot/s of mine on Lorry who has had a bath today and is ready for his rego inspection tomorrow.
Please ignore the ugly bugga in the reflection.
Insert now Inserted......
Last edit: 3 years 1 month ago by Sarge.
Time to create page: 0.510 seconds
